Old 12th March 2004, 04:55 AM   #1
bowdown is offline bowdown  Australia
Default Toroidal Voltage problem
Hey there evryone, im hoping sombody out there will be able to help me sove a problem i am having.Well this is how it goes....
I have a 1500VA Toroidal With primary of 240V and secondaries of 66V, theoretically once it is rectified i should be getting approximately +/- 92V, well this is not the case..... i measured the secondary ac voltage which is actually correct but once it goes through the bridge rectifier i am only getting +/-65V and i have tried 2 rectifiers that were bought at the same time and the same place!!!
these are all no load voltages, i have checked high and low on the net and the forums but cant find anything that can help me solve the problem...Pleeeaaase help if you can as i am desparete.
If you need more info please let me know.
Bowdown
Old 12th March 2004, 07:12 AM   #2
djk is offline djk
djk's Avatar
It helps to hook up some capacitors too.
Old 12th March 2004, 09:08 AM   #3
Yeah i tried that as well but still the same problem, i am using 50,000uF per rail(5 x 10,000uF caps)...
Old 13th March 2004, 03:38 AM   #4
kilowattski's Avatar
I do not see how it is possible to get your readings with the capacitors attached. With no capacitors attached you are actually reading the correct voltage. You are actually reading the RMS value of the ripple with your voltmeter which is about 65 Vdc (reference the top figure). With the capacitors connected and no load you should read about 91 Vdc. The capacitors charge to the peak value and there is no (relatively little) resistance to discharge them (see the bottom figure). You can easily verify this with an oscilloscope.
Kilowattski
Old 13th March 2004, 04:39 AM   #5
mwh-eng is offline mwh-eng  United States
I think most DVMs will read the average voltage when set for DC volts. RMS is an AC voltage reading, right? I agree, with the circuit properly wired with capacitors and no load, a DVM should read the peak voltage less rectifier(s) voltage drop.
Old 13th March 2004, 04:51 AM   #6
The one and only
Nelson Pass's Avatar
Well, something is wrong. It might be that the transformer
is mis-labeled or mis-represented. It happens to even the
most reputable companies. Talk to the vendor about your
problem. If he is any good, he will help you. If not.... don't
despair, I wouldn't want 92 volt rails myself anyway. There
are lots of other deserving projects. Maybe this is a blessing
in disguise.
Old 13th March 2004, 05:01 AM   #7
Make sure the bridge rectifier or discrete rectifier rating is 400 PIV. A 200 PIV is marginal and a 100 PIV may cause your problem if they are breaking down (conducting in reverse bias) between 100 and 200 volts. Just a wild guess.
I agree that + and - 90 VDC rails is awful high!
Good Luck
Old 13th March 2004, 08:19 AM   #8
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
If you have everything wired as in the image below there is something wrong with the bridge rectifiers/transformer. I'd go with two 400V/25A or 400V/35A bridges if you haven't done so yet...
some 'good' SS power supply 'literature':
http://www.tnt-audio.com/clinica/ssps1_e.html
http://sound.westhost.com/power-supplies.htm
http://sound.westhost.com/psu-wiring.htm
Old 13th March 2004, 08:28 AM   #9
Bowdown,
I am sure you have done it right, but just in case, make sure that
you have the meter set to DC when you are measuring
the voltage over the caps. I think we had a similar case recently
where someone turned out to have the meter set to AC, which
gives the wrong result for DC.
Old 13th March 2004, 08:42 AM   #10
Default mwh-eng
Wow, I stand corrected.....I can't believe I wrote RMS, and I wasn't even drunk at the time. I don't know what I was thinking?
Kilowattski
Pearl voltage problem dzkh63 Pass Labs 6 4th March 2005 03:10 AM
Voltage problem sith Tubes / Valves 10 7th January 2005 12:20 PM
Best Transformers (Encapsulated Toroidal or Open Frame Toroidal) Rixsta Pass Labs 10 23rd April 2004 03:41 AM
Voltage Regulator Problem? fmak Solid State 43 16th April 2002 11:24 PM
Toroidal secondary voltage for Aleph Jmertz Pass Labs 6 16th January 2002 07:30 PM
Page generated in 0.11008 seconds (75.65% PHP - 24.35% MySQL) with 11 queries
