Spectral DMA-50 distorted output - diyAudio
Old 16th December 2016, 03:41 AM   #1
Default Spectral DMA-50 distorted output
So a friend of mine cleaned out his garage and gave me this amp. Only problem is that the left channel runs pretty clean at very low volume but gets distorted as volume is increased. The right channel is distorted all the time and has very low output. Any ideas where to start looking. The boards seem pretty simple but I have no expertise and no schematic so looking for any advice.
BTW, there are a grand total of 6 electrolytic caps in the entire amp: 4-330uF caps on the driver board and the two big ps caps
TIA
Old 22nd December 2016, 10:13 PM   #2
Any thoughts on where to look?
Old 22nd December 2016, 11:19 PM   #3
rayma is offline rayma  United States
Try emailing diyaudio member 1audio.
Old 29th December 2016, 12:17 AM   #4
Thanks!
Old 29th December 2016, 12:18 AM   #5
Thanks!
Were you able to get any information or help?
Old 5th January 2017, 12:44 PM   #6
Still working on it. The holidays delayed it a bit but I sent him photos and I am waiting to hear back.
Old 5th January 2017, 01:46 PM   #7
tvi is offline tvi  Australia
tvi's Avatar
Default re DMC-10 and DMA-50 from the designer
Originally Posted by 1audio View Post
In my experience those amps are pretty durable. The output transistors (Hitachi's) are nearly bulletproof. If it is oscillating the output network would heat up and the heatsinks will get hot but no other bad side effects. It was designed to deliver full power to 500 kHz. If the components were unable to handle that then we would have lots of smoke in testing.
The problems with that amp are: first, thermal cycling will cause the connections between the outputs and the circuit board to get flakey. They may need to be resoldered. Second the bias may have drifted. Its open loop so it should be checked. I don't remember the settings.
FET failures are easy to spot, the gate current goes up. If there is a measurable voltage across the gate resistor the device is blown. However if its working and doesn't have offset it should be fine. The heatsinks will run warm.
The preamp is even simpler. The output protection circuit is its problem. Just remove the LM339 and it will sound better. As usual thats a fix for the earlier preamp that was not necessary for this generation.
took me a while to find this, hope it helps
regard
james
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 6th January 2017, 02:01 AM   #8
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
can you share any good, detailed photos of the internals?
i always liked looking at Spectrals DMA products that Demian had a hand in ...
mlloyd1
Old 6th January 2017, 02:18 AM   #9
expert in tautology
bear's Avatar
I have the schematics in a binder, never scanned.
The good part is that the circuit is pretty simple.
The first step is to do the usual troubleshooting methods, check for shorted devices, visually inspect for bad solder connections. look for broken/cracked resistors.
Then bring it up on a variac slowly and observe the line current draw AND the DC offset.
That needs a scope. And a signal, sine or triangle for input...
The amp ought to be stable DC wise by about 35-40vac of line voltage, I would expect.
IF nothing is blown up, and both channels seem to amplify, WITHOUT DC offset, then check the bias... the bias pot may be open and the devices more or less cut off - or maybe someone got in there and turned the pots. (entirely possible).
Fwiw, that is an amp with a bandwidth, iirc of ~1mHz!!
If you give up on it, I would buy the chassis from you, just to muck around with it...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 10th January 2017, 01:19 PM   #10
mlloyd1
Here are some photos.
I had removed the board to look for burn spots and look at the solder joints and everything looked ok. I will go back and check a little more closely.
I do not believe the unit was ever opened prior to me so everything (including the pots) are undisturbed.
I don't have a scope so I can't look at waveforms (don't know if I would know what I'm looking at either...)
Bear,
If you can scan the schematic, I would be most appreciative. I will send a pm.
JL 500/1 distorted output mbates14 Car Audio 3 2nd October 2012 07:35 PM
Amp with distorted output Mote Car Audio 5 23rd August 2012 08:17 PM
wtb Spectral DMA 50 soundalot Swap Meet 0 17th May 2011 03:10 PM
spectral DMA-360 jonstanza Solid State 0 6th September 2010 03:11 AM
Amplifier Output Distorted Rotellian Solid State 12 10th May 2006 02:49 PM
Copyright 1999-2017 diyAudio
