diyAudio Moderator Emeritus
I have a strange problem with an amp. The casing is made of aluminum and steel plate. When I slap/hit the casing, it makes sound to the speaker (output). I check the electronic circuit, and it seems nothing is wrong. How can I fix this?
#2 |
Is it tube or solid state?
#3 |
It is solid state. The amp is monoblock. The left is ok, but the problem is with the right unit. I check the voltages, nothing is different, no other complain, just this strange casing noise. What I'm afraid that this is a begining of something worse, if it is not fixed immediately.
#4 |
My inclination would be to look for a cold solder joint or a loose connection.
#5 |
Patient: "Doctor, doctor, it hurts when I raise my arm over my head!"
Doctor: "Don't raise your arm over your head." Capacitors are often microphonic. I doubt it's anything to worry about. And stop slapping your amplifier! |
#6 |
One month ago both are fine. Why is it only occur to 1 amp? Is there a capacitor drying? I've check the connections they all OK, have to check for cold solder. Infact now, nothing is wrong with the sound, just makes me a bit worried.
Charles, I'm not intentionally slapping my amp. Just find it out unintentionally. |
#7 | |
I agree that it's likely microphonics due to something physical. Modulating capacitor plates? |
#8 |
I don't buy the microphonic solution. I still think it's just a bad connection.
#9 | |
A bad solder joint would make a different sound than microphonics, don't you think? We need an MP3 sound file to listen. A cold solder joint would probably sound noisy and harsh. Maybe a microphonic sound would be more like high speed tremelo or vibrato effects. |
#10 |
I've recheck the whole amp. Nothing seems to be loose or bad solder (they are dull, right?)
The sound semms like a slight "echo". When I slap the casing (sorry, Charles), it gives an echoed slap to the speaker. What is the cause? |
| strange hum problem | zeus_threat | Solid State | 8 | 18th December 2007 02:55 PM |
| strange amp problem!!! | moonchild | Solid State | 23 | 14th January 2006 12:05 PM |
| strange amp problem | feelander | Car Audio | 1 | 8th June 2005 07:21 PM |
| Strange little problem (or maybe not so) | elizard | Chip Amps | 8 | 4th January 2004 06:25 AM |
| Page generated in 0.11927 seconds (77.40% PHP - 22.60% MySQL) with 10 queries |
