Research into IGBT audio amplifier. - diyAudio
Old 9th December 2016, 09:13 PM   #1
nigelwright7557's Avatar
Default Research into IGBT audio amplifier.
I am having a go at making a 150WRMS into 4 ohms quasi audio amplifier using a pair of IGBT's.
The igbt's are NGTB35N65FL2WG.
Does anyone foresee any problems with this ?
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 9th December 2016, 11:53 PM   #2
Hint: Crop and invert colours prior to uploading. Hard to read even at 100% with very modest pixel density.
Old 9th December 2016, 11:58 PM   #3
I have cropped it.
My picture software wont invert it.
Old 10th December 2016, 03:02 AM   #4
Your previous schematic posts feature inverted colours (i.e black background, white traces) and large format. While unusual, that is at least legible. I have to agree that a schematic in this format for PCB design, is difficult to read and follow so I resorted to sketching what could be read onto paper.
Ian
Old 10th December 2016, 01:29 PM   #5
xrk971 is online now xrk971  United States
xrk971's Avatar
That image has been down sampled and makes fonts illegible. Even when it was legible, the non standard symbols and disproportionate scales for components makes it very hard to understand or follow.
The diagrams from LTSpice are better and Tina is an improvement over that even. Best ones are of course, hand made in a graphics program. My vote for best looking and most elegant schematics are from Apex Audio and Juma. Juma looks like he uses ASCII characters for graphics.
Old 10th December 2016, 08:29 PM   #6
Its simply too much info zoomed down to fit on a screen.
There are no fonts, the text is a vector character set.
I should have split it into two and zoomed out one step.
Old 11th December 2016, 09:34 AM   #7
SyncTronX's Avatar
OH, I guess we know what software not to use,
listed in the sig of Nigel.
It's worse than bad video games of the 60's.
errr, make the 70's or 80's.
Y'all are right, non-standard symbols and other issues
color problems...almost looks like a screwed up four color sep
and they got the colors wrong....oh it must be before the plate y'all.
It's late, shut eye time.
cheers,
-- Sync
Old 11th December 2016, 09:49 AM   #8
nattawa is online now nattawa  Canada
Instead of posting a direct screen shot of it, either printing the schematic into a pdf, or screen shooting a print preview if the monitor has high resolution, usually turns whatever the background color to white, and will perhaps make your critics happy
Old 11th December 2016, 04:21 PM   #9
cheers,
I am not going to get bogged down in stupid off topic comments.
I can read the latest screen shots with no problems and have little sight in my left eye !
I was hoping to get some serious comments on the IGBT amplifier.
Old 11th December 2016, 05:07 PM   #10
jerluwoo's Avatar
With the large input capacitance and rather high turn on voltage, I'm not seeing any real advantage in using these igbt's over pure mosfets of the same power range.
Audio Research D90... a HOT, buzzing amplifier JacquesPlafond Tubes / Valves 37 17th December 2015 03:46 PM
Audio Research D51 tube power amplifier rayma Swap Meet 7 4th November 2015 08:02 PM
AUDIO RESEARCH SP-6B TUBE AMPLIFIER samchen Tubes / Valves 6 9th October 2013 01:29 AM
Class D audio power amplifier research rob mullen Class D 31 15th November 2008 09:30 PM
WTB:Audio Research LS-5 Pre-Amplifier postman56 Swap Meet 0 6th February 2006 01:15 PM
Copyright 1999-2017 diyAudio
