Old 5th December 2000, 10:30 PM   #1
I am in the process of building the Pass A40. But since I discovered this forum I have come across other S/S amps like the Mjamp, Andrea Ciuffoli etc. If anyone has anymore could you please let me know. Thanks
Old 6th December 2000, 06:47 PM   #2
Eric is offline Eric  United States
Eric's Avatar
Lightbulb Other DIY amp plans
Here are a few other amps:
http://sound.au.com/projects.htm
http://users.ece.gatech.edu/~mleach/
http://www.homestead.com/whaan/files/index.html
http://www.sealelectronics.com/
http://www.infomaniak.ch/~bonavolt/hir20.htm#Hiraga 20W
By the way, how far along are you on the a40 design? I've been spending the past few weeks tracking down the necessary parts. I still cannot find the 1W 5% wirewound resistor, and am having trouble finding a suitable toroidal transformer. Have you found your transformer yet?
If you are interested, I'll post the URLs for the remainder of the a40 components I have found...
-Eric
[Edited by Eric on 12-06-2000 at 01:53 PM]
Old 6th December 2000, 07:31 PM   #3
Default a40
Yes I am interested in the links you have for parts. Digikey has the 1 Watt wirewounds. http://www.digikey.com
The transformer I will be ordering from Plitron @ http://www.plitron.com I have not yet decided to use 1 or 2 transformers yet. Today I will start etching the boards (or at least that was the plan) so really not very far along at all yet. I have the transistor or replacements so I may need to do some tweaking but they should do the trick. The heatsink I'm going to try and talk my brother into making (hes a machinist) Keep me (us) updated on your progress.
Thanks for the links!
Old 6th December 2000, 07:53 PM   #4
Eric's Avatar
Lightbulb a40 Parts, Supplier, and Cost list (UPDATED)
For the sake of simplicity and maintenance, I have moved my complete parts list to here: <a href="http://www.facstaff.bucknell.edu/esantane/movies/a40.html">Pass Labs a40 Parts List</a>
[Edited by Eric on 06-06-2001 at 08:57 AM]
Old 6th December 2000, 10:32 PM   #5
Plitron has transformers that will work no need to custom order. I sent Mr. Pass an email questioning him on the transformers. All you need is 22 volt secondaries (22 times 1.4142 yields about 30 volts) and he indicated the A40 draws about 100 Watts per channel. So double the wattage for saftey (200 watts) that equates to a 400 VA (both channels) and you can always make it larger.
My DigiKey catolog maybe different I am from Canada and they have seperate catologs, but they should have them. I show them having Yageo wirewounds 5 and 10 Watts with .68 ohms. I wouldn't worry to much about finding 1 watt a 5 watt should work just as well.
Etching isn't as hard as it may sound. I use the toner transfer method. Have tried the photo method but it failed terribly. http://www.eng.uci.edu/~rshah/pc-board.html andhttp://www.al-williams.com/wd5gnr/pcb.htm are good sites. Although the price of the boards from Old Colony sounds good.
Mr Pass addresses not using the same devices he did in the article. I think (without looking at schematics) R11 may need to be tweaked to achieve the correct bias.
Keep in touch happy hunting!
Old 7th December 2000, 04:04 PM   #6
Eric's Avatar
Question a few more questions
OK, found the 5w 5% wirewounds - I wasn't sure if these would adequately substitute for the 1w resistors. I've updated my links above for the parts.
Next, I think I'm starting to figure out the rating scheme for transformers. First, a question about 22 volt secondaries: Why are you multiplying 22v by the square root of 2 to obtain 33 volts? Where does the sqrt(2)come from? From the bridge? Going back to Nelson's design, it appears that the specified transformer (118v primary, two 44v secondaries, 8A) is WAY more (704va primary!) than this design actually needs. Is this correct?
It looks like (using your logic) I could use a (slightly larger than needed) 400VA primary with two 25VA secondaries - should be more than enough. Is this correct?
Finally, I remember seeing Nelson's warning about substituting parts but the original output transistors are no longer available... Other people seem to have used the Motorolas without any trouble.
Thanks for your help!
[Edited by Eric on 12-07-2000 at 11:06 AM]
Old 7th December 2000, 05:03 PM   #7
Smile AC Theory
Its been a long time since I used AC theory so if anyone else can explain it better please do so. But 1.4142 is used to find the peak voltage. A DVM on AC volts typically takes an RMS value or average. (AC is a sine wave) So for 115 VAC the incoming peak would be 162.6 VAC. So 22 volts would give 31.1 Vac peak. If you really want to get fancy in the bride there will be 2 volt drops because of the diodes. For theory say 0.7 volts per diode for 1.4 Volts. So really your left with 31.11 - 1.4 = 29.71 VDC. In the real world it may end up higher transformers are not perfect.
HOpe this helped
Old 7th December 2000, 07:35 PM   #8
Eric's Avatar
Exclamation toroids and power rating
Thanks for the explanation of toroid power ratings. I was looking around some more and found a good section in the description of Heatsinking for the Pass Labs A75 power amp:
http://www.passlabs.com/projects/a75_2_8.htm It relates heat to power in the context of transformer and heatsinking selection.
Did you get a price quote from Plintron about the transformer cost? It looks like there is an appropriate transformer on the sealelectronics home page: http://www.sealelectronics.com/misc.html It looks like transformer #3 will do nicely, and have plenty of power left over for headroom. I was wondering how the prices compare (SealElectronics gets transformers from Plinton)...
Old 7th December 2000, 08:22 PM   #9
Smile toriod
Transformer 3 as I see it has 40 volt secondaries. This is much to high. 40 volts * 1.142 = 56 volts for the A-40 you want about 30 volts. You need a transformer with about 22-24 volt secondaries with a VA rating of at least 400(VA).
If you look in the A-40 article under Final Tests you will see N. Pass is expecting +- 32 volts. http://www.plitron.com part # 757015201 has 400 va rating and 22 volt secondaries cost $53.00 US or $73.00 Canadian. Once again you may want to go with a higher VA rating than 400VA. Or use two seperate transformers with ratings of 200VA or higher. I emailed a fellow from Australia and he is using 2 - 350VA transformers.
I know you haven't started construction yet but when you do be very careful! The transformer is rated for close to 10 Amps. If you are inexperienced with high voltage I would enlist the help of someone who is. The power supply caps will knock your butt if your lucky! Saftey first!
Once again hope this helped
Old 8th December 2000, 02:24 PM   #10
Eric's Avatar
Unhappy A little confused?
I think I have found the source of our differences in the voltage specification for the secondaries:
The specs in the design document for the amp call for a transformer with "two 44v, ct, 8A secondaries". Is this an error? Based upon what is said later on in the article (Final Testing, as you point out) it seems that the transformer should be a 44v (total) secondary arranged as 22v + 22v in parallel. Is this correct?
This then keeps voltage at ~30v for each channel (22*1.4142).
Thanks for the warning on the power caps - I'm aware that they hold a significant charge for quite some time. I'm thinking of bypassing the large caps with smaller ones for discharge when the amp is shut off...
First DIY solid state amp sblack6 Solid State 5 8th June 2009 02:10 PM
Solid State Voco Solid State 1 24th October 2004 09:05 PM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 05:26 PM
Page generated in 0.12310 seconds (82.23% PHP - 17.77% MySQL) with 10 queries
