Old 10th March 2004, 10:59 PM   #1
Bukitoo is offline Bukitoo  Argentina
Default Balanced Input Stage
HI !!!!
I have a question for U guys.
Maybe you tried these solutions and want to share your experience.
I was looking for solutions for building my own guitar preamp, but I get to many "strutures".
One of them is the instrumentation amplfier. Another is using a differential pair as input.
Others solutions use a couple of transistors in many configurations.
I was wondering wich of those introduces less noise and distortion. Im very newbie
Thanks in advance !
Old 11th March 2004, 12:20 AM   #2
The one and only
Nelson Pass's Avatar
If you want the ultimate in rejection, RF proofing, isolation
and so on, check out a Jensen transformer. You can find them
on Google, and they're in Hollywood and are very nice people.
Old 11th March 2004, 12:57 AM   #3
Banned
the input stage of you guitar amp, or a little preamp inside the guitar?
Old 11th March 2004, 01:13 AM   #4
I just try to design an external preamp.
But many posibilities!!
Old 11th March 2004, 01:14 AM   #5
dalbjerg's Avatar
First of all, it’s ok to bee confused.
I can understand that you have been looking at some “Instrument” amplifier circuits.
Those are not for music instruments. The name come from laboratory equipment and is often used in the input stage of measuring instruments.
For electrical guitar you use a singe-ended (“normal”) input and not a differential.
You should post your question in the Musical Instruments forum.
Here are a few good links to start building your own amp-
http://blueguitar.org
http://www.diyguitaramp.com
http://sound.westhost.com/projects-5.htm
If you can’t join them beat them.
Old 11th March 2004, 03:03 AM   #6
Oddly enough, you don't want a low distortion circuit for a guitar amp. The trick is to have enough of the right kind of distortion. It's not the same set of requirements as home audio.
Note that all the solid state pieces try to sound like tubes. All the classic amps, Vox, Fender, Marshall, etc. are tubed. The one exception to this is that sometimes a "clean" sound works well for bass. Never for guitar.
It's been a while since I've pawed through his archives, but Ned at www.triodeelectronics.com used to have a wide assortment of schematics, including guitar amps. Most if not all of them will be tubed, but they can give you ideas for topologies.
If you're wanting to go solid state you're going to be using a lot of opamps.
If you search the web, you can find schematics of various amps, although you'll have to go to a dozen different places to get a good overview.
Grey
Balanced input stage beneficial for unbalanced turntables? leadbelly Analogue Source 37 28th April 2008 01:34 PM
Balanced line stage- input or output attenuator nobody special Pass Labs 4 7th April 2006 01:18 PM
input switching design for balanced line stage ijomojo Pass Labs 3 23rd January 2005 02:02 PM
balanced input stage sonix Tubes / Valves 54 5th June 2004 02:47 PM
balanced diff. input stage Altaic Solid State 15 21st July 2002 10:07 PM
Page generated in 0.08668 seconds (71.55% PHP - 28.45% MySQL) with 10 queries
