quasi complementary amplifier 2n3055 pcb - diyAudio
Old 20th November 2016, 07:24 AM   #1
Legion is offline Legion  Poland
Default quasi complementary amplifier 2n3055 pcb
I have a lot of old 2N3055 transistor so I wanted to build a quasi complementary amplifier, I searched a lot, but coudn't find a good pbc layout. So does anybody have a pcb layout for it ?
Old 20th November 2016, 05:45 PM   #2
indianajo's Avatar
The Apex AX6 works. PCB layouts are in this thread: Retro Amp 50W Single Supply
With real homotaxial process (1968-1975?) parts, don't exceed about 60 v rail voltage (no minus voltage on this schematic). Unless you test for acceptable leakage current with base shorted to emitter at what higher voltage you choose. Newer parts can be tougher at higher voltage than the original design parts.
Use a regulated power supply rail. AX6 doesn't have a lot of constant current transistors that reject power supply variation. You can use a 2n3055 as a series pass power supply regulator, but you'll need a booster transistor with a heat sink (TO220 or TO5) to sense the zener diode and drive the base of the 2n3055. Or if you're ordering a box of something, a couple of parallel TIP142 darlingtons are ~$1 each, the emitter current sharing .33 ohm resistors are 5 for $1. I used five TIP142 parallel for two channels of output transistors, but I listen to classical music and like a lot of current occasionally for the cannon shots or drum hits.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 20th November 2016, 05:57 PM   #3
apexaudio's Avatar
There is BX100
Current Dumping Amplifier
2N3055 inside - commercial famous amplifier models, quasi complementary power output tiefbassuebertr Solid State 246 5th December 2016 05:12 PM
How to identify a quasi-complementary amplifier? motbuddy Solid State 48 20th August 2016 07:01 AM
Op Amp buffer/amplifier, quasi-complementary, need advice. wponline Solid State 11 26th September 2012 02:22 AM
Quasi complementary outputs in a full complementary circuit xeclipse Solid State 12 11th January 2011 08:35 PM
Quasi complementary outputs in a full complementary circuit xeclipse Solid State 0 26th December 2010 08:08 PM
Copyright 1999-2017 diyAudio
