Grounding question - diyAudio
Old 19th October 2016, 09:08 PM   #1
Default Grounding question
Hi all
just working out the wiring for a pair of Lang 20W Class A amps, and am a bit confused about the grounding.
http://gdurl.com/6Rsz
The amp uses 2 supplies - 20V @ 4A (output stages) and 24V @ 100mA (low level stages). As you can see on the board layout, there is a 0v connection, and a 'T' connection. Any ideas?
thanks
Old 20th October 2016, 10:58 AM   #2
Every inter-module connection needs two wires.
Keep every two wire connection as a close coupled pair.
Twisted, or coaxial, is slightly better if the size and type of cable suits.
eg.
From power supply A you need two wires. A dual polarity PSU needs three wires, twist these as a triplet.
From power supply B you need two wires. A dual polarity PSU needs three wires, twist these as a triplet.
From Audio Source Left channel you need two wires.
From Audio Source Right channel you need two wires.
Speaker Left output needs two wires.
Speaker Right output needs two wires.
Transformer secondary to rectifier needs two wires.
Install all those two wire connections.
Now compare your assembly to the schematic and find any missing connections.
Unfortunately the PCB layout designer did not agree with this most basic philosophy.
He has provided many connections as single pads. He has forgotten that current cannot flow around a circuit unless a route is provided for the return current to go back to it's source.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th October 2016, 11:05 AM   #3
it's more about the connections on the circuit board - there is one marked '0v', and one marked 'T'. My understanding is that the 'T' goes to the main star ground, but the '0V' - is that for the 0V return of the low current supply, or for the signal ground?
Old 20th October 2016, 11:08 AM   #4
AJT is offline AJT  Philippines
AJT's Avatar
this is what i use....
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 20th October 2016, 11:12 AM   #5
post4 is wrong. Pavouk.org got it completely wrong and AJT should never have copied it. He has been told before and chooses to post this erroneous layout yet again.
Never take your audio ground to the main charging node between the smoothing capacitors ! NEVER !
regards Andrew T.
Old 20th October 2016, 11:16 AM   #6
The problem is that there does not appear to be a signal ground connection on the board. Unless, as I said, that is the '0V' connection pin near the output transistors, which seems a bit odd.
Old 20th October 2016, 11:20 AM   #7
AJT's Avatar
never use the power supply ground return wire to run your signal grounds, use a separate wire....
run those wires separately to the psu common or zero point...
Old 20th October 2016, 11:23 AM   #8
Many will disagree with you on that. The input gets it's return own path to the star ground. What's wrong with that?
Old 20th October 2016, 11:24 AM   #9
You need to do a bit of reverse engineering comparing the schematic to the layout to find the best place to tap into the return part of the circuit, for least interference.
That will not be easy.
regards Andrew T.
Old 20th October 2016, 11:26 AM   #10
AJT's Avatar
i have been using that layout even before Pavouk published it, as early as the early 90's
it works for me, no reason it will not work for others....
nothing is....
the speaker negative or return wires go back to the star....
never use one wire for the two channels, run them using separate wires,
i never run speaker grounds to the board and then to the starr,
i use separate wires....
so you seem in the schematics there may be fewer lines,
but in the actual buildm there are more wires than the schematic called for....
Yet Another SSE Grounding Question timhowell Tubelab 1 21st August 2014 02:47 PM
Grounding question... Pooch Tubelab 5 8th May 2014 11:56 PM
Grounding question graygem Analog Line Level 9 20th March 2014 01:40 AM
Grounding Question bigbillc Pass Labs 25 2nd January 2010 02:00 AM
grounding question skyraider Chip Amps 1 9th March 2004 10:12 AM
Copyright 1999-2017 diyAudio
