Hello can anyone tel me if the LYNX Amplifier will work with darlingtons on the output ? Should i ommit Q110/Q111 ?
I have BDX66c/67C rated 120v 16A 150W . Can i reach 150W/8ohm with 2 pairs at +/-60v ?
B.I.G |
#2 |
PS: the amp can be found here http://www.audio-circuit.dk/PDF/Sche...LYNX_v2-1E.pdf
B.I.G |
#3 |
First of all, I have told Jan that there is a question regardig the lynx amp out here on diy. The transistors you want to use are rated for 120 Vce, this means that voltages above this will cause the transistor to fail, or in worst case breake down. If you want to run the amp at +-60V I suggest you use transistors rated at no less than 200V 15A. These could be the 3281/1302 pair or their newer substitutes 1943/5200 Hope this helps you \Jens |
#4 |
I've got your email, and have tried several times to email you, however my reply keeps bouncing back with "Mail Error Handler".
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#5 |
from where i`m form you can`t fiind good bipolars only fakes so it is very hard for me to go for a 200V rated device . I have seen MJ15003/4 amps going on +/-68V that`s 136V they are 140V . With my transformer +/-60V no load i can get about +/-58V .....
B.I.G |
#6 |
Okay so i have only found ON MJ15022 rated at 200V , 250W
MY question is can i use only the MJ15022 NPN of course you would have to tell me what mods to do !! How much will this affect the sound quality of the amplifier ?
B.I.G |
#7 |
The MJ15022 are just fine!
I don't think you will hear any difference at all using these substitutes... I can't hear it
#8 |
I didn`t express my self corectly !
I only found the NPN MJ15022 !! I couldn`t fiind the PNP MJ15023 I hope this amp can work with NPN only
B.I.G |
#9 |
No way!!!!
You can find a few amps using only NPN's, but not this one
#10 |
It won`t work at all or it will just sound badly ?
B.I.G |
| The LYNX v3.0 150 Watt Bi-Polar Power Amplifier | Ayne | Solid State | 7 | 14th December 2008 04:04 PM |
| Lynx 3 | dodi_firman | Solid State | 43 | 11th January 2008 04:09 AM |
| LYNX Power Amplifier Board Group Buy | fungustchan | Group Buys | 5 | 7th March 2006 09:49 PM |
| Lynx from ACD Help | led_zeppelin | Solid State | 8 | 16th September 2005 03:22 PM |
| Lynx amplifier using Mosfets | Dusk | Solid State | 7 | 16th July 2005 11:26 PM |
| Page generated in 0.11189 seconds (69.38% PHP - 30.62% MySQL) with 11 queries |
