GainWire mk3 CFA pre/phone amp with very low distortion
Old 2nd November 2017, 09:20 PM   #301
JPS64 is offline JPS64  Germany
The Printed Board Assembly (PCB + components) could be directly screwed on heatsink, bottom plate enclosure (no vias)...
The cost for metal core PCB is surprisely cheap (35m, 1.55mm thickness).
JP
Old 10th November 2017, 10:01 AM   #302
dadod is online now dadod  Croatia
dadod's Avatar
I almost finished wiring, but encountered one big problem, input selection boards do not work, not connecting any input. This is Volume and input boards bought called Biino from diy-audio-shop.de | Platinen und mehr (Birger Maass). Unfortunately the shop is closed from this summer and no answer from Birger. Hi is a member on this forum and I've sent PM but no answer too.
The main control board I received is a bit different than the schematic in the shop and it looks when I change the input nothing was sent to the input board.
Display works correctly, even the volume control board.
I am desperate now and if, just in case, anyone has experience with this Biino I would appreciate any help.
Damir
Old 11th November 2017, 01:56 AM   #303
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Originally Posted by JPS64 View Post
First attempt using metal core PCB...
JP
Hi JP, may I know what is a "metal core PCB" and who offers these types of PCB's, I haven't heard of it before.
Old 11th November 2017, 03:35 AM   #304
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
PCB made of aluminum or even copper substrate vs FRP for better heat dissipation for SMT devices that rely on PCB as heatsink. LED lights use this a lot. But I see now that power amps with SMT MOSFETs or BJTs would benefit as well. There is a dielectric layer between the copper trace and the board itself.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 11th November 2017, 07:33 AM   #305
@Ultima Thule
IMS pool – Aluminiumkern-Leiterplatten-Pooling von Eurocircuits – Eurocircuits
Only single electrical layer (more = other technologie see Wrth) and avoid vias.
JP
Old 11th November 2017, 10:18 AM   #306
oh I see, that's excellent these types of aluminum PCB's have become more mainstream, probably the explosion of LED market have pushed it in favor to us diy'ers, I have to admit I am so badly updated these days, thanks for the info, vielen dank!
Old 20th November 2017, 05:58 PM   #307
rsavas is offline rsavas  Canada
How can we help when we have no info on this design. I see on the web site some pcbs and a mcu.
Biino | diy-audio-shop.de
Old 20th November 2017, 06:11 PM   #308
Got Foam?
xrk971's Avatar
JP,
Is that a GW Mk3 in SMT?! Wow you are fast. It had no label and looks so different I couldn't be sure - but based on parts count, it is I believe a GW Mk3.
Old 20th November 2017, 07:39 PM   #309
dadod's Avatar
This is Biino control board, volume board and input board.
http://www.diy-audio-shop.de/produkt-kategorie/biino/
Old 20th November 2017, 09:06 PM   #310
still need to know a bit more about the
like where is the schematic you refer to.
GainWire mk3 CFA pre/phone amp with very low distortionHide this!Advertise here!
Silicon Chip ULD Mk3 amp - 0.0006% distortion Circlotron Solid State 51 27th November 2016 05:13 AM
ultra low dist pre Sandman distortion null padamiecki Analog Line Level 13 23rd April 2014 05:19 PM
tube pre amp for phone stage hunsoop Tubes / Valves 15 1st May 2009 01:31 AM
Low Distortion High Dynamic Range Pre-amp Nico Ras Pass Labs 64 18th May 2007 05:26 AM
Power Supply For Pre/ Head Phone & Phantom... (PCB) Ayne Power Supplies 0 28th April 2007 04:10 PM
