P3A Power supply
P3A Power supply
Old 8th March 2004, 08:46 PM   #11
kenk168 is offline kenk168  United States
Question too much uf per rail
"Also, IMHO 20,000uF per rail is overkill - go with 10,000 per rail and save yourself some money."
I am building the power supply for the P3A as well and I have a question. Since I do have 8 4700uf caps, should I use all 8 (4 4700uf per rail) on this? Also, some folks say too much caps slow down the amp, is this true?
Please advice,
Thanks,
Ken
Old 9th March 2004, 06:55 AM   #12
cabbagerat is offline cabbagerat  South Africa
No. The only negative effect that more caps have in this position is to seriously increase inrush current at turn-on. It's not a problem if you aren't too attached to your fuse.
If you are pushing the amp hard, or into 4 ohm loads, then it's worth using all the caps. If not, then save them for something else.
Old 9th March 2004, 03:39 PM   #13
Thanks,
As my speakers are rated at 4 ohm, I will use all those caps.
Ken
P3A Power supplyHide this!Advertise here!
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
