Hi guys
I hope this is not a too stupid question, but here goes: I have a Naim NAC42 pre that I got in a trade for duplicate LPs I had. It came without a PSU, so I want to build one for it. Just to start off I want to build it from parts I have in my parts bin (some I go from friends, some I got from stripping old equipment). I have a small 18V-0-18V trannie (about 50W - 80W) as well as a pair of huge caps (65000uF, 35V) as well as a pair of 21000uF caps. I got both pairs from a friend of mine(he got it from a mainframe he stripped), and I would like to use them to build a split 24V-0-24V PSU for the Naim (seperate rails for the phono-stage and pre sections). I also have a 25A brigde rectifier from a failed amp project- I tried building a JLH 10 Watt class A amplifier a few years back, but I think the transistors I used were all blown (they came from another amp I got). My question is this- will the trannie not be harmed by the huge current draw of the large caps? I will add other smaller caps to the equation as well (to add a bit of speed), so in total the capacitance of one rail can get as high as 90mF - 95mF! I hope this is not a too stupid question Enjoy, Deon
Reality is not digital, an on-off state, but analog. Terry Pratchett - Moving Pictures |
#2 |
The capacitors will only draw a large current on initial power up. This short duty surge should not matter to the transformer. I see no problems.
#3 |
I thought it might not be an issue (I remembered the massive supply for Hiraga's Le Monstre), but I just wanted to be sure. I will probably build a better supply as funds allow- this is just for experimentation.
BTW, what do you think will sound the best: A. A regulated PSU as per normal Naim amps (using LM317 regs), or B. A C-L-C, or even a C-L-C-L-C, choke-rectified PSU? I tend to lean toward the double-Pi filter (i.e. C-L-C-L-C), but I would like hear other's opinions/experiences Enjoy, Deon
| F5 Power Supply Caps Seem Small | NV&H | Pass Labs | 3 | 23rd January 2009 01:41 AM |
| WTB: Pana FC small caps | cartman | Swap Meet | 0 | 15th November 2008 01:16 PM |
| Low voltage (and small) audiophile caps | slowpogo | Parts | 1 | 26th February 2007 06:50 PM |
| Paralleling small value caps with large value PS caps | xyrium | Power Supplies | 16 | 14th October 2005 04:06 PM |
| WTB: Small quantity of 0.1uf 0805 SMD caps | theAnonymous1 | Swap Meet | 15 | 29th September 2005 04:48 AM |
| Page generated in 0.08706 seconds (65.60% PHP - 34.40% MySQL) with 10 queries |
