Adcom GFA 555 Overheating with remote volume control?
Old 7th July 2016, 01:19 PM   #1
Snobeeler is offline Snobeeler  United States
Default Adcom GFA 555 Overheating with remote volume control?
Hi all, I am having a issue with my Adcom GFA 555 overheating and shutting down when I use a Niles Audio VCS 100k speaker volume control for my outside speakers (Paradigm 9SE). This happens at any sound levels. When I eliminate the Niles Volume switch the amp runs cool. I have used a different (not sure what make) volume control in the past with no issues. It is still at my previous house unfortunately. I have verified all wiring is correct and undamaged. Can anyone advise on what might be wrong? Thanks
Old 7th July 2016, 01:47 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Snobeeler,
That control doesn't look like it will handle very much power. If the transformer cores saturate, they could present a very low impedance to the amplifier. The output volume isn't the problem, it's how much power the amplifier is delivering that can overtax the transformers. Does that control have a rating for the maximum power it can handle?
Best, Chris
"Just because you can, doesn't mean you should" my Wife
Old 7th July 2016, 07:38 PM   #3
The specs said it could handle 100 watts. I know my 555 is much higher than that. The most I turn up the volume is moderate for short times. Could I have damaged the volume controller in some way that it is now causing my problem. as I think back the 2 months I have been using it, it appeared to work fine, its only recently the issue showed its face. Thanks for the help.
Adcom GFA 555 Overheating with remote volume control?Hide this!Advertise here!
Adcom GFA-555 eelekim Pass Labs 2 14th May 2009 03:42 PM
adcom gfa-5300 left channel overheating n8tron Solid State 0 16th January 2009 09:20 PM
Adcom GFA-555 claiborne Solid State 8 27th September 2007 10:20 AM
FS:Adcom GFA 555 and GFA 5300 trusound Swap Meet 0 13th December 2005 05:06 PM
