Old 1st March 2004, 08:32 PM   #1
hegestratos's Avatar
Send a message via ICQ to hegestratos Send a message via AIM to hegestratos Send a message via MSN to hegestratos
Default dual voltage SuperRegulator?
Some time ago I got interested in building a Gilmore headphone amp [1]. I'd like to power it from using a SuperRegulator. As I understand it, this amp requires well matched positive and negative supply voltages. Mr. Gilmore's powersupply uses an inverting power opamp to achieve this. All the SuperRegulator designs that I have seen only provide a single voltage, so getting a good match between the positive and negative side would require quite some resistor matching and tuning. Then one can only hope the whole thing doesn't drift too much due to temperature change and such.
I thought I'd slap together a positve and negative SuperReg, but replace the voltage reference with an opamp inverting the positive voltage reference. The advantage would be that no resistor tuning is required. Also, any drifts in the reference will be copied to both rails. It still requires resistor matching, but 0.1% resistors in the critical places should do.
What drawbacks are there to this approach? Is it worth persuing?
Thanks,
Alfred
[1] http://headwize2.powerpill.org/proje...lmore3_prj.htm
Old 2nd March 2004, 07:14 AM   #2
diyAudio Retiree
"What drawbacks are there to this approach? Is it worth persuing?"
Fears about the necessity the supply voltages being matched and tracking each other unfounded. The tracking on the current sources is much more important than the supply voltages. If one wants to do something to improve this supply I would put my efforts into bypassing the adjustment terminals for the regulators and filtering the reference noise with the right value caps.
Starting with a 48 V supply is unnecessary and will destroy the regulators if the input to ADJ becomes greater than 30 something volts (check data sheets for exact numbers). Worrying about drifts and matching of a few millivolts is a waste of time. A decent op amp cost as much as or more than another voltage reference like the LM329. I can't see any advantage to it other than the fact that perhaps he didn't think of how to get of a negative voltage from a REF 02 series voltage reference. Most people use shunt references like the LM329 which make it a no brainer for a negative reference.
Claims of open loop distortion products less than 80 dB and line rejection of 120 dB are kind of unlikely. The voltage changes of this amount on the output of the regulator from noise on the input of the regulator would be well below the noise floor and difficult to verify. I believe the Jung type regulator would be a real improvement over this supply. The positive supply tracking the negative extremely closely is a non-issue. Even the supply shown in the article could be greatly improved with a few capacitors and resistor.
Old 2nd March 2004, 09:18 AM   #3
I'm not planning to upgrade the regulator proposed by Mr. Gilmore - I don't even want to use it. I want to replace it with a Jung type reg.
Drifts, okay, 10ppm/K is not enough to make me worry. Matching, however, is. In the LM329 datasheet, it says Vz is between 6.6 and 7.25V, 6.9V typically. Worst case scenario for a +-14V supply would be 1.32V difference. That's 4.7%. This, to me, seems like a lot.
Of course, in the Jung circuit, it could be solved by tuning the voltage dividing resistor pairs. Resistors are cheap, so buying a metric boatload is not a problem. Solving Vout = Vref * (1+r1/r2) and (r1*r2)/(r1+r2) = 500 for r1 and r2 gives r1 = 500 Vout/Vref and r2 = 500 Vout/(Vout-Vref). Aiming for Vout = 14V and Vref between 6.6 and 7.25V gives 965.5 < r1 < 1060.6 and 945.9 < r2 < 1037.0 Ohm, which is still quite a range. Maybe a ~950 Ohm resistor plus a precision trimmer?
Old 2nd March 2004, 11:04 PM   #4
diyAudio Retiree
Default since you are quite serious about this........
"Of course, in the Jung circuit, it could be solved by tuning the voltage dividing resistor pairs."
I think if you buy a batch of LM329s you will find less than a couple of tenths of volts between devices. If really want to trim the supplies that close, put a much larger resistor than the value between the reference and it's filter cap, across the filter cap to ground to form a voltage divider for the small difference in reference voltages.
WHAT EVER YOU DO, MAKE ABSOLUTELY SURE THAT YOU THERMALLY COUPLE THE LM329S (SELECTED FOR CLOSELY MATCHED TEMPCO) TOGETHER IN THE FIINAL CIRCUIT. MEASURE THE FILTER CAPS LEAKAGE CURRENTS TO MAKE SURE THEY ARE EQUAL. I WOULD LET THE CAPS SIT AT THE VOLTAGE THEY ARE TO BE USED AT FOR AT LEAST A WEEK AT MAYBE 35 TO 50 DEGREES CENTIGRADE BEFORE EVEN BEGINING TO MATCH THE LEAKAGE CURRENT. BE VERY CAREFUL TO USE RESISTORS WITH A TEMPERATURE COEFFICIENT NO MORE THAN 25 PPM/C, ACTUALLY 10 PPM/C WOULD BE PREFERABLE.
http://www.eeel.nist.gov/
Old 4th March 2004, 07:56 PM   #5
diyAudio Retiree
Unhappy I wasn't so serious.........
RE:since you are quite serious about this........
Everything in caps after the exclamation icon was satire.........Sorry.
Old 4th March 2004, 10:46 PM   #6
Default Re: I wasn't so serious.........
Really?
I'm admittedly new to electric engineering, but I do have a solid physics background. I'm capable of logic thought. I do appreciate your (serious) comments.
That being over with: your suggestion of a resistor across the reference's filter cap would allow me to tune a reference voltage down. It's a nice solution, but not very flexible.
I'm putting a small trimmer pot with the wiper on signal ground between the two resistors to the inverting inputs of my two opamps (R9 in the ALW schematic). That way I can adjust the gnd to be exactly in between the two rails. The drawback is that I no longer have a real star ground.
Alfred - wonders if he's actually listening to what Fred is saying
Old 23rd March 2004, 11:55 AM   #7
Sheriff is offline Sheriff  United Kingdom
Sheriff's Avatar
Send a message via ICQ to Sheriff Send a message via MSN to Sheriff
Default I was wondering about this PSU / amp combo....
Hi Hegestratos,
I was wondering if anyone had used ALW's super reg with the KG class A amp....
Please keep me / us posted as to how you get on, and good luck with the build.
Best Regards
Sheriff
Old 23rd March 2004, 12:01 PM   #8
Electrons are yellow and more is better!
peranders's Avatar
Fred, it's rather pointless if the reciever doesn't understand or probably not understand
/Per-Anders (my first name) or P-A as my friends call me
Old 23rd March 2004, 12:07 PM   #9
peranders's Avatar
hegestratos, I think the Gilmore amp can do very well with two ordinary Jung Regulators. I see no need for tracking voltages.
You may also use LM431 with a little bit more precision. 431 has more noise but I'll doubt that this is a big problem.
Maybe you should join the ALW group order?
http://www.diyaudio.com/wiki/index.p...+pcb+group+buy
Old 23rd March 2004, 01:11 PM   #10
Sheriff's Avatar
Default alw group buy finish date
Hi P-A,
I thought that the finish date for the group buy was the 21st of March.
I would have been up for 4 x pos, and 4 x neg.
Sheriff
Dual battery PSU with low voltage changeover dwitt4 Power Supplies 5 3rd April 2007 11:05 PM
problem with dual +/-15V voltage regulator sunrise Pass Labs 2 23rd June 2006 06:17 PM
Low voltage noise dual OP Holger Barske Parts 7 24th May 2004 06:57 AM
LA5667 dual voltage regulator rbroer Parts 3 6th July 2003 02:38 PM
Page generated in 0.12587 seconds (83.90% PHP - 16.10% MySQL) with 11 queries
