Old 29th February 2004, 05:00 PM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default Opamp in class A?
I have been reading a little about biasing an opamp in class A,and as I understand it you have to use a resistor according to the output load,but what if i use different loads on the output for listening test and other,will a CCS solv this problem?And how do I construct this ? "never done sommething like this before"
Old 29th February 2004, 05:50 PM   #2
The one and only
Nelson Pass's Avatar
You can buy a monolithic current source, or you can make one
easily enough. Try a resistor first, just for kicks.
For Class A, usually you want the bias to be as high as the
current to the load. For a resistor, this is easy - just use a
value (usually to the negative rail) the same value as the load.
Usually something like 10 K will do the job fine.
Old 29th February 2004, 06:28 PM   #3
Maybe this link will be of some help:
How to bias opamps into class a operation
/Niclas
Old 29th February 2004, 06:29 PM   #4
Since the person asking the question was from Sweden, just one
word of caution. Those monolithic current sources (constant
current diodes) that are easily available in Sweden (ie. at Elfa)
are spec'd for a minimum voltage drop of 10V. Hence they may or
may not work depending on the op amp supply voltage and the
signal amplitude. Discrete CCSs can be built to work with smaller
voltage drops.
Old 29th February 2004, 06:40 PM   #5
PMA is offline PMA  Europe
PMA's Avatar
Although it depends on OpAmps circuitry, the current source (sink) from output to -Vs (negative supply rail) does usually the job.
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
moving opamp to Class-A anli Chip Amps 1 10th December 2004 05:09 AM
opamp class a again pxr5 Solid State 0 9th November 2004 05:24 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
opamp 'class A' biasing?? rsrphotos Solid State 2 28th September 2004 10:24 PM
Page generated in 0.08704 seconds (73.64% PHP - 26.36% MySQL) with 10 queries
