Elusive noise on left channel - diyAudio
Old 20th May 2016, 01:45 PM   #1
redrooster's Avatar
Default Elusive noise on left channel
Im having trouble chasing down this noise Im getting on the left channel but only on Tape 1? Phono,Tuner,Tape 2 are all OK its just this damned Tape 1 thats doing it? The sound is an intermittent crackling sound like a bad transistor or a broken solder joint,Ive DeOxited all the pots and changed the switch on Tape 1 just in case it was faulty. Could it be coming from LC7815H? Its a 2 pole 4 position Analog Function Switch thats obsolete now.The amplifier is a Sansui A-909.
Old 20th May 2016, 01:58 PM   #2
Mooly's Avatar
There doesn't seem much else tbh. You should as a definitive test perhaps desolder tape 1 L and R inputs at the chip and then carefully crosslink them so that L feeds into the R chip input. That would rule out anything weird like conductive spillage or leakage. The problem should remain on the same left channel if he chip is faulty. Might also be worth isolating that 4066 in case its backfeeding anything into the audio path.
Old 20th May 2016, 02:30 PM   #3
redrooster's Avatar
Ah yes! Good one Mooly.Why didnt I think of that? Thanks mate, Ill get right onto it.
Old 20th May 2016, 02:36 PM   #4
JonSnell Electronic's Avatar
My money is on the 4066 leaking internally.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 20th May 2016, 02:59 PM   #5
redrooster's Avatar
Could I just take LC4066 out instead of cutting some tracks?
Old 20th May 2016, 04:19 PM   #6
redrooster's Avatar
I disabled the VDD and VSS power by de-soldering two links to LC4066, it got rid of that noise,the volume was really low but only on Tape one and if I changed to say Phono I get a big thump in the speakers. It looks like these LC4066 chips are still available. The tape monitors not needed but muting that thump certainly is. I found some badly wave soldered ribbon connections so I might pop those links back in and see if it was that causing the noise?
Old 20th May 2016, 05:32 PM   #7
Mooly's Avatar
The 4066 is a common CMOS chip available anywhere. It doesn't have to say LC on it. The 4016 is similar apart from having a slightly higher 'on' resistance.
Old 21st May 2016, 12:20 AM   #8
redrooster's Avatar
Oh thats good, I might be able to get one locally instead of waiting for 2 or 3 weeks to get parts in the post. lol Thanks Mooly.
Old 3rd June 2016, 03:23 AM   #9
redrooster's Avatar
The 4066 chip just arrived in the mail I installed it but the noise is still there? Ive replaced the momentary switch on that function as well so the only thing left is the LC7815 chip. It seems strange that it would only fail on one function but the tuner and phono go through it OK? Ive just remembered I desoldered a 6 pin ribbon lead that was for a retro remote on Phono,Tuner and Tape 1. Ive marked it on the schematic. It hasnt affected the Tuner or Phono though? lol
Old 3rd June 2016, 06:50 AM   #10
Mooly's Avatar
Its probably going to be the LC chip. Replacing or isolating the 4066 was just to prove (or disprove) that it wasn't influencing anything.
If you have done other work (the ribbon) then it might be worth putting all back to original condition to see if that proves anything.
Noise in left channel - modded SE 40 Danzhifi Sonic Craft 10 12th May 2013 11:50 PM
rockford 1000a2 noise in left channel stoke Car Audio 24 12th June 2011 12:43 AM
rotel RA-311 left channel noise mogga Solid State 3 26th February 2011 08:17 AM
help with some Left Channel Noise... vandalfsens Solid State 3 27th October 2010 03:57 PM
Crackling noise in left channel. fritz39 Solid State 1 20th January 2009 11:57 PM
Copyright 1999-2017 diyAudio
