Transistor relay circuit - Page 2 - diyAudio
Old 19th May 2002, 03:30 AM   #11
Warp Engineer
On Holiday
AudioFreak's Avatar
the audio signal does not pass thru the coil (inductor) of the relay and so very little damage is done to the signal..... transistors do quite a bit of audible damage.
Old 20th May 2002, 07:59 PM   #12
but then why doesn't an amplifier produce a huge amount of noise? i thought that most amplifiers used transistors in them. but ok. i think i get the idea, use relays if i can, transistors only for other signals.
if only it could be used for good, not evil...
Old 21st May 2002, 01:37 AM   #13
Warp Engineer
On Holiday
AudioFreak's Avatar
The idea is this...
If you use a remote soft start circuit, you can use a transistor to trigger this. Use relays for the power supply rails to minimize heat and relays for the signal input switching / output protection etc just use transistors (BJT or FET) when you need a buffer, gain stage etc where transistors can not be avoided.
muting transistor>relay,can i do this? Rodzilla Analogue Source 2 18th December 2016 07:40 AM
Relay switching circuit please jnewbold Solid State 10 3rd March 2005 06:39 AM
Quick relay/transistor question Prune Parts 5 9th August 2004 02:54 PM
Momentary relay driving circuit dine1967 Solid State 7 8th April 2003 08:02 PM
Power-on relay circuit, i/o connector 2Bak Everything Else 1 15th March 2003 08:25 PM
Copyright 1999-2017 diyAudio
