Old 26th February 2004, 09:52 PM   #1
maylar is offline maylar  United States
Default favorite prototyping boards
What do you guys recommend for prototyping (protoboards)? I see them advertised on eBay with anywhere from a couple hundred to over 2000 tie points. Some have power supplies built in and some don't. What do you guys use, and what do you "wish" you had?
dave
Old 26th February 2004, 10:06 PM   #2
Bill Fitzpatrick's Avatar
I use various sized protoboards and an external supply for +/-25v variable tracking. Tracking means that as you adjust one knob both the + and - voltages change by the same amount.
Old 26th February 2004, 10:33 PM   #3
johnnyx is offline johnnyx  United Kingdom
I use stripboard, "Veroboard", for prototypes; I'm wary of the integrity of the contacts on plug-in boards for anything but the simplest low power circuits. It requires soldering, but can be fairly quick, and if it works it will last a surprisingly long time.
Old 26th February 2004, 10:59 PM   #4
True, protoboards do have current limitations and are not really suited for power amps.
If you're doing pre-amps, active filters, logic and other low power stuff the protoboards are great. I've had protoboards as large as 8"x10" populated with dozens of ICs and hundreds of resistors/caps. Doing this with a vero board would have been out of the question.
Old 26th February 2004, 11:12 PM   #5
SY's Avatar
More than that, protoboards are usually made of nylon, which is quite hygroscopic; the dielectric properties are dodgy and change with humidity. They're fine for circuits which are totally non-critical of stray capacitance and leakage. Add to that the tendency for the contacts to deteriorate with use and to shave bits of metal off of leads causing unexpected shorts, and you do truly have what Pease calls a "slab of grief."
Besides, they don't make these for vacuum tubes!
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 26th February 2004, 11:34 PM   #6
I agree with SY . . . but
I've never experienced these problems and I've been using them for 20+ years.
Cult movies - what is your favorite - what is your favorite part Ken L The Lounge 243 15th February 2010 04:09 AM
Electro Boards SMD Prototyping davidallancole Parts 0 30th April 2008 05:10 PM
Prototyping with SMD ezkcdude Digital Source 6 23rd May 2006 11:39 AM
Is there interested in teflon prototyping boards? patriz Parts 4 19th November 2004 05:20 AM
Prototyping a 100W CFB amp... OliverD Solid State 15 7th March 2004 08:53 PM
Page generated in 0.09497 seconds (76.14% PHP - 23.86% MySQL) with 10 queries
