GainWire mk4 fully balanced line amp - diyAudio
Old 22nd April 2016, 09:46 PM   #1
dadod is offline dadod  Croatia
dadod's Avatar
Default GainWire mk4 fully balanced line amp
GainWire mk4 fully balanced line amp from the input to the output with no GNFB.
Quite low distortion, excellent CMRR, very low nose(fixed signal noise ratio at all volume sets).
Schematic, Gain, CMRR
Damir
Old 22nd April 2016, 09:48 PM   #2
dadod's Avatar
FFT.
Old 22nd April 2016, 09:49 PM   #3
dadod's Avatar
Noise.
Old 24th April 2016, 08:06 AM   #4
dadod's Avatar
I hopped for some comments and suggestion here, but nothing.
It is first time I do fully balanced pre amp. The idea was to use GainWire mk2 as starting point. That pre amp can work as NGNFB and as it is a current conveyor there is possibility to put the volume pot at the current conveyor output instead input and with it get a big advantage of a fixed signal/noise ratio independent of the volume pot setting.
Now there I had idea to use only single volume pot for the balanced volume regulation, but that sims is not so good idea. Distortion is higher then if double volume pot with the middle grounded is used. Distortion specially goes up at low volume settings.
Attached the simulations to show that
edit: second picture should, of course, the volume pot of 4k to have the same gain, but still it shows the idea.
Old 24th April 2016, 01:41 PM   #5
So it's basically a gainware mk2+gainware mk2?
Old 24th April 2016, 02:53 PM   #6
dadod's Avatar
Yes, but only in NGNFB, no CFA. A volume pot is after input gain stage and output buffer and it change the gain of the input stage.
No NFB line amp (GainWire mk2) dadod Solid State 1000 3rd December 2016 01:47 AM
Silicon Chip ULD Amp Mk4 tabrocky Solid State 4 18th April 2016 04:13 AM
how to implement line level bsc on a full balanced setup? PreSapian Analog Line Level 4 7th March 2014 07:50 PM
Which first watt amp for Zu Druid mk4? boidos Pass Labs 12 20th August 2009 10:50 AM
ZAPsolute Mk4 - AMP Kit Repute Solid State 13 29th January 2002 09:40 PM
Copyright 1999-2017 diyAudio
