Rotel output fuse
Rotel output fuse
Old 25th February 2004, 09:28 AM   #1
miguel2 is offline miguel2  Portugal
Default Rotel output fuse
One fuse on the output of my Rotel 921 has blown. As I had no output on the left channel I opened it and saw it was the fuse. then I put the right channel fuse on the left channel and it was OK. So I may have made some short or something.
The fuse is labelled T4L250V. As it seems to be in series with the output signal I wonder if this is a regular fuse or something special. If I have to go to something else, what should I use?
Miguel
Old 25th February 2004, 10:28 AM   #2
Tensop is offline Tensop  Lebanon
just a standard fuse
Old 25th February 2004, 10:38 AM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Rotel output fuse
Not quite.
There's standard fast-blow and slow-blow.
T4 indicates time-delay (slow-blow) 4A. L250V indicates 250V rating.
Old 25th February 2004, 11:08 AM   #4
So a slow blow 4A 250V will be ok? Are there different types for slow-blow fuses?
Rotel output fuseHide this!Advertise here!
amp blown fuse = output offset ? AndrewT Solid State 42 13th November 2014 06:45 AM
Fuse between B+ and output transformer? Evenharmonics Tubes / Valves 16 7th May 2008 06:51 PM
Output fuse Anvil Solid State 9 25th April 2004 07:13 PM
HELP: Rotel RB 980bx fuse lucianos Solid State 2 21st December 2003 06:07 AM
aleph output fuse MikeZ Pass Labs 7 9th November 2003 09:05 PM
