BA283 AM Biasing Trimpot Issue?
Old 29th February 2016, 02:34 PM   #1
lesabb is offline lesabb
Default BA283 AM Biasing Trimpot Issue?
I am newbie and trying to build the pre-amp section of the Neve 1073. I decided to bread board the BA283AM ONLY as per the attached schematics. I think there is a problem but i canít seem to find it. The collector voltage on the 2N6248 is 20.6V. Shouldn't it be higher? When I turn the trimpot nothing happens. The Base voltage is ~10.6V and the E is at ~ 10V, which I think is OK but a bit higher than previously reported (~3V). Consequently, the C voltage of Q1 is at ~10.6V (much higher than the reported 3.6V). The transformer is connected to the 24V PSU and to the output of the BA283AM as per the schematics.Any troubleshooting ideas? Thanks
Luc
Old 29th February 2016, 03:34 PM   #2
Cortez is offline Cortez  Hungary
Cortez's Avatar
Try to simulate this cct. Then you will know how it works and then you can compare the reality to the values in the sim.
BA283 AM Biasing Trimpot Issue?Hide this!Advertise here!
Kicker kx350.2 biasing issue EBBCO Car Audio 9 21st October 2012 08:42 PM
How to create a DC offset trimpot? reiver Solid State 13 15th June 2008 01:38 PM
low-biasing or high biasing in Class-AB amps kASD Solid State 124 18th October 2005 04:45 AM
Strange biasing issue when adjusting VBE EWorkshop1708 Solid State 30 6th July 2005 05:17 AM
