1943-5200  temperature issue
Old 25th February 2016, 10:26 AM   #1
east electronics is offline east electronics  Greece
east electronics's Avatar
Default 1943-5200 temperature issue
Repaired one amplifier which is working and biased according to specs in "class A " which in real life means high bias class AB
The specific application is 4 output transistors per ch supplied with 38+38 volt and each transistor is biased at 410ma which is a bit lower than specified in the manual
HTC is all brand new, plenty and fresh everywhere and the mechano work is done as best is possible everything is very tight considering the assembly
The result is about 57 degrees on the mount area of the transistors while fins of the heatsink will be a few degrees lower ...
Do you think that this is safe enough ?
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 25th February 2016, 11:01 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Semiconductors; Power dissipation starts to degrade above 70 C.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 25th February 2016, 11:05 AM   #3
R.I.P.
One would need to do a simulation for the temperature de-rated SOAR to compare to the loadings imposed on the output stage.
That is not a quick bit of guesswork.
regards Andrew T.
Old 25th February 2016, 11:31 PM   #4
Bigun is offline Bigun  Canada
Bigun's Avatar
I do. Because for most normal listening levels this amp will stay in Class A. It has 400mA x 4 = 1.6A per side. Into 8 Ohm that's 10W already and with Class A the more the music plays the more power goes into the speaker and less for the transistors.
But what about the ambient - you have a nice cool workshop, will customer use it in Greek summer when it is 30C in the house ??
Maybe put a temperature cut-out switch on the heatsink and put it in series with power supply.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 26th February 2016, 08:35 AM   #5
Proper vbe multiplier exists in both ch located in proper area and double thermal cutoff separated for both ch exists already in the amplifier .
Thanks Gareth !
Old 26th February 2016, 04:59 PM   #6
44ct357 is offline 44ct357  South Africa
HI
chuck the junk in the bin and use tip35/36C from st micro, make sure same batch number for audio perfection!
44ct357 CT SA
1943-5200  temperature issueHide this!Advertise here!
how to match the Transistors like toshiba 5200 1943 rhythmsandy Solid State 3 26th February 2016 05:06 PM
toshiba 2SC5949 2SA2121 better than 5200 1943? rhythmsandy Solid State 6 19th November 2013 08:55 AM
how to manage psu for the car amplifier? with 5200 1943? rhythmsandy Solid State 4 16th June 2013 10:29 AM
does a single pair of 5200 1943 total 2 needs matching? rhythmsandy Solid State 4 9th March 2013 06:07 PM
LME49810+5200/1943 better than opa549 rhythmsandy Chip Amps 0 5th December 2012 08:39 AM
