Frankenstein NGNFB Amp - diyAudio
Old 8th February 2016, 04:55 PM   #1
dadod is offline dadod  Croatia
dadod's Avatar
Default Frankenstein NGNFB Amp
I will try to design a NGNFB amp with an OPS with no EC, as this is also a kind of NFB. I would like not to use negative feedback except local degeneration.
I chose IPS(input stage) a current conveyor very similar as in GainWire mk2 but with higher gain of about 32 dB. Characteristic I like about current conveyor is that the gain is defined with resistors only. The volume control is at the output of the current conveyor. In this case SNR is always the same independent of the volume settings. Disadvantage is that distortion is the same on all volume settings(for IPS only).
First OPS I choose is non switching design by Edmond Stuard. Interesting thing about that OPS is the same THD on almost all levels, it drops only below 1 - 2 W on output. I expect some more ideas for OPS, preferable Class B(AB).
Damir
File Type: jpg FRANKESTEIN-GainWire-EdmondOPS-sch.jpg (143.8 KB, 341 views)
File Type: jpg FRANKESTEIN-GainWire-EdmondOPS-gain.jpg (191.1 KB, 322 views)
File Type: jpg FRANKESTEIN-GainWire-EdmondOPS-FFT.jpg (141.1 KB, 291 views)
Old 8th February 2016, 06:12 PM   #2
vzaichenko's Avatar
Send a message via Skype™ to vzaichenko
Hi Damir,
Interesting project! From my side, I can offer a non-switching OPS, based on bias clamping principle - see the OPS schematic here:
NS-OPS schematic
Showing rather low distortion open loop. Well tested in live builds.
A good layout update, suitable for 3281/1302 type of output devices is designed by Marc (idefixes), shown here:
NS-OPS compact layout
Valery
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
See my projects at VIRTUAL ZERO distortion AUDIO
Old 9th February 2016, 04:37 AM   #3
dadod's Avatar
Thank you Valery,
I will simulate and report back what I got.
Cheers, Damir
Old 9th February 2016, 04:36 PM   #4
dodo is offline dodo  Poland
What is the reason to design and build and amp with 32dB and more gain heaving the preamp with at least 6dB gain.
I would prefer to see the amp with twice lower voltage gain to siut YouTube Gain Wire preamp
Old 9th February 2016, 04:52 PM   #5
dadod's Avatar
If you read carefully what I wrote in first post you will see volume control inside IPS, P1. Here no preamplifier is needed, GainWire mk2 is practically inside the IPS, that's way I choose the gain of 32 dB.
What is YouTube Gain Wire preamp?
Old 9th February 2016, 04:58 PM   #6
vzaichenko's Avatar
Standard gain of the power amplifier is 29db. It's good to have it close to that value for being able to exchange tha power amps seamlessly in the system.
Old 9th February 2016, 05:47 PM   #7
dadod's Avatar
Valery, please read what I wrote, this is not standard amp.
Old 9th February 2016, 05:53 PM   #8
vzaichenko's Avatar
That was addressed to dodo, you just managed to post quicker than I did
32db with volume control is definitely ok.
Old 9th February 2016, 08:26 PM   #9
Ok, but if the preamp has 15dB gain ??
Old 9th February 2016, 08:35 PM   #10
dadod's Avatar
You don't need a preamp with this one, it has enough gain.
The volume control as implemented here keep SNR of the amp equal for all output levels. As level is going down, noise is going down too, this is how current conveyor is working when the gain is going down by decreasing current conveyor output resistor, P1 in this amp. I hope that is clear now.
GainWire-NGNFB-classB-PowerAmp dadod Solid State 114 17th October 2014 06:41 PM
frankenstein lives blurkzzz Multi-Way 1 3rd June 2012 12:40 AM
Project Frankenstein ORNJ Analogue Source 0 7th March 2012 11:04 PM
Frankenstein ppereira Tubes / Valves 20 17th December 2006 07:48 PM
Frankenstein tube amp karma Tubes / Valves 6 4th July 2004 03:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
