#11 | |
You'd avoid the Miller capacitance-multiplying effect in a similar way to a cascode, too. Erik
Would a woodchuck bother to chuck MDF? |
#12 |
This isn't directly on subject, but what do people think of the vacuum tube LTP differential crosscoupled cascode amplifier?
#13 |
Please don't hijack my thread. It is so easy to start a new thread in the vacuum state section - you might even get some replies...
#14 | ||
diyAudio Moderator Emeritus
After reading that old thread, it shakes my believe again. First, I learn that distortion comes from fluctuating voltage and fluctuating current. The fluctuating current is remedied by putting big standing current (bias current), so the percentage of signal is small compared to bias current (class A). The fluctuating voltage is remedied by cascodes, that is to lock the operating voltage of the gain transistor. I tought that is it. But that old thread discuss about how cascodes gives "FATIGUING" sound for long time listening. Actually I still have questions, why Mr. Nelson Pass seldom use cascode, inspite he has his own patent on cascodes? He only uses it for small FETS or dividing thermal dissipation. Is it true, while cascode can help with measurement figures, it is bad for listening? What is the reason behind it? Quote:
#15 | |
its going to be difficult to do a “apples to apples” comparison of folded cascode vs current mirrors given the number of inversions necessary to create a negative “current feedback” connection not being the same you could try adding a common source output amp to circuit #2 but then you are also testing nested vs global feedback schemes as well |
#16 |
The source follower buffer on the first circuit did little if anything to the simulated distortion figure. I would only use it when the circuit has to interface with the cold, cruel world of uncertain impedances. The current mirrors in the second circuit are only there for the bias, to make sure that the two current source loads are reasonably equal, and as benificial fallout, also to provide bias for the cascode transistors. The same thing could be done in countless other ways, but bipolar transistors are cheap...
#17 |
So sad, I took a closer look at the circuit on the right, jcx, and it does have positive feedback. For some reason, it didn't flop over to one side in simulation like it should. Shame on me for not staring at it harder...It could be fixed by adding another inverting stage or by returning the feedback to the input, but I'm not too interested in either approach. It looks like my folded cascode measurements will be confined for the time being to my power amplifier, once I get all the mods done and coax it back into its case. Now that one has proper negative feedback...
| Class A/B folded cascode amp | roender | Solid State | 17 | 17th July 2007 02:08 PM |
| folded cascode | the_tool | Chip Amps | 1 | 27th June 2006 09:53 PM |
| Symmetrical folded cascode. | Mr Evil | Solid State | 195 | 1st April 2005 03:15 AM |
| Folded cascode question | Won | Solid State | 3 | 11th January 2002 07:10 PM |
| Page generated in 0.09117 seconds (83.02% PHP - 16.98% MySQL) with 11 queries |
