Old 20th February 2004, 08:57 PM   #1
maylar is offline maylar  United States
Default Analog VCA's
Anybody know of a source (or schematic) for analog voltage controlled amplifiers?
The single-chip implementations I've found so far are very expensive.
dave
Old 20th February 2004, 09:30 PM   #2
mirlo is offline mirlo  United States
Analog VCAs typically depend on circuits like Gilbert cell multipliers with added distortion reduction circuitry. The operation of these circuits is heavily dependant on precise matching between transistor characteristics. It is difficult to imagine that you could obtain such matching with discrete components, almost certainly you would end up spending more than you would on a monolithic solution.
Old 20th February 2004, 10:31 PM   #3
Steven is offline Steven  Netherlands
Steven's Avatar
Not only Gilbert is famous for his multiplier, also Blackmer. His circuits are more related to audio. He died two years ago and many VCA's from That are based on his design. His famous gain cell is patented: 4,403,199 and you clearly see all the matched transistors that are required. Where the Gilbert gain cell requires only NPN (or PNP) transistors, for Blackmer's cell you need matched NPN's and PNP's. See picture below.
See also: http://www.thatcorp.com/vcahist.html for some background info.
Next to ICs from That Corp., maybe the VCA's from Analog Devices, who took over SSM years ago, are more cost effective, like the 4 channel VCA SSM2164. For the datasheet on the 2164 see the link.
http://www.analog.com/UploadedFiles/...786ssm2164.pdf
Or use the VCA part of a cheap compander IC, like the Philips/Signetics NE572 (family).
Steven
Old 21st February 2004, 02:39 PM   #4
Thanks very much for the Analog Devices part link - I dunno why it didn't come up for me when I searched their site. At $5.86 (DigiKey) for 4 units it's the most cost effective solution I've seen.
The THAT Corp parts are about $9 US each. And Burr-Brown has one (SSOP only) for a whopping $28.
I'm intending to try using one as a variable frequency active filter circuit. Multiple stages cascaded with a single control. At .02% THD they're not too bad.
dave
Old 21st February 2004, 05:32 PM   #5
Steven's Avatar
Have a look at http://www.rane.com/sac23.html
That unit uses the 2164 as a voltage controlled filter. Schematics are given in the link.
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 22nd February 2004, 04:40 PM   #6
Outstanding. Thank you, Steven.
Dave.
dave
Old 10th November 2005, 08:01 PM   #7
I have a commercial synth with M5222L VCAs connected to it. They are very noisy.
They are connected to +6 and -6v and the pot controlling them is going between -6v and 0v.
What can I do with this? Bypassing is the solution provided for a camera using the same VCA. The only thing is that a synth without volume control is not great and 4 channel pots with good tracking are hard to find.
Here's the signal path:
PCM55HP DAC -> 4x 4053B Analog Mux/Demux sections -> 4x TL064 opamps sections -> Stereo M5222L VCA -> 2x TL064 sections -> Relays -> outputs
Someone told that replacing the TL064s by OPA4134s did a great improvement but that it still was bad.
Antoine
http://dmsaudio.ca/
Old 11th November 2005, 03:44 AM   #8
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Hi Maylar,
Try this Link and download the datasheet of Analog VCA LM13700 IC
http://www.national.com/ds.cgi/LM/LM13700.pdf
Hope that it helps...
K a n w a r
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
USB to analog GnuNielsen Digital Line Level 4 28th July 2009 08:44 PM
Digital or analog? xplod1236 Digital Source 1 19th May 2005 02:15 AM
ANALOG(UE) is KING davesaudio Everything Else 1 14th November 2003 04:17 PM
Analog IC switches, how to use? Hybrid fourdoor Parts 7 3rd October 2003 03:16 AM
5.1 HT Analog Pre mcp Solid State 0 31st May 2003 02:52 AM
Page generated in 0.14578 seconds (64.55% PHP - 35.45% MySQL) with 11 queries
