Hiraga "Le Monstre" 8 W - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Old 2nd February 2016, 01:50 PM   #1
TIC37 is offline TIC37  Sweden
Default Hiraga "Le Monstre" 8 W
I know that there is already some threads running on this subject but I have a small question not mentioned anywhere about the caps required for the power supply.
I own a Monster that was bought many years ago from Holland and it has original components on the PCB .
At that time I was not into diy that much and even less about the electronics behind things even though I have a Master in engineering. I know my physics and some electronics but had not devoted myself into building things at that time.
Ok, problem is that I had a minor accident with the amp, cause when shipped to Sweden the capacitors had been falling from their position (glued to the bottom of the case and no other support) and I, happy for my new Monster, couldn't wait to "fire" it up so due to contact between chassi and capacitor bank I had a small "fire" and some capacitors where destroyed.
Some time after this accident I met a person who said he could fix this and so he did..... by his own head and got it working but not accordingly to the original set up (the amp that I bought was not having a correct power supply either). The amp is working but I have some hum and also some undefined cracking sounds so I have now decided to do a real check up since I have starded doing my home work about electronics. The cracking sound I have isolated to bad contact somewhere in the power supply but the hum I am absolutely shure is because of the bad construction of the existing power supply.
My idea is to build the power supply accordingly to the picture below
Now my question is, the batteries are parallelled with amongst others, a supercap 0.47 F but what voltage should be choosen??
I presume I should at least have 12 V (since I am parallelling 12 V batteries) but that is getting tricky, have problem finding those values.
Any help out there??
Carpe Diem
Old 2nd February 2016, 08:28 PM   #2
soundhappy's Avatar
Attachment 528769
Ahoy TIC37
Very interesting project.
This is original psu schematic for " Le Monstre " from L'Audiophile by J Hiraga.
On last photo noise figure of classic psu are much higher
if compare with noise level of battery psu Have fun !
class A amplifiers with full range speakers
sings like angels in heaven
Old 2nd February 2016, 08:49 PM   #3
the main reason for humming le monstres is the lack of signal / power gnd separation on the original amp pcbs
if you want to go crazy with the psu caps use modern parts should be easy to cram 5 -10F in the same space as the original without supercaps
Old 2nd February 2016, 08:54 PM   #4
soundhappy's Avatar
For your psu version 12 V battery's are smaller 6Ah version and bypassed
with Nec supercapa 0,47 F decoupled in parallel with 2,2 uF polycarbonate.
Old 2nd February 2016, 10:13 PM   #5
Default About super or ultra caps
I have everything to sgart building the power supply except for the batteries (ordered and home in a week or so) and the super/ultra caps.
Have been looking at Mouser, Digi-key, Farnell and Elfa but I dont find 0.47 F in 12, 14, 16 volt. My question is if anyone here have a clue where to find these??
Carpe Diem
Old 2nd February 2016, 10:38 PM   #6
soundhappy's Avatar
3 supercapa's rated 5V connected in series = 15 V is OK
Try find 10 V so you need two connected in series = 20 V is the best solution
6 or 4 scaps for this amplifier
Old 2nd February 2016, 11:02 PM   #7
Default ohps!
True, sometimes the answer is like the foredt you don't see because of all the trees.
So used to find everything in the shops listing that you forget obvious electronic knowledge. Thank you for the help.
Carpe Diem
Old 2nd February 2016, 11:18 PM   #8
soundhappy's Avatar
Some supercapa have nicer longer legs for easy & stable
series solder connections make good choice
ps. type in the center are not easy to connect imo
File Type: jpg 754ACB9E-15D8-496A-A7CB-00AD3F9CE2B1.JPG (41.1 KB, 49 views)
Old 3rd February 2016, 03:21 PM   #9
juma is offline juma  Germany
juma's Avatar
Don't waste your money, those toy caps can supply about 1mA max.
They are intended as memory back-up in low consumption circuits.
Old 3rd February 2016, 04:15 PM   #10
soundhappy's Avatar
Hi Juma
This Nec Supercaps are special for psu with battery only decoupling.
After research in battery psu construction NEC is described in Audiophile article
with graph and despite his limits work in this particular use.
Supercapa (G.Chrtien)
Do you have ready build battery powered amplifier or experiment with ?
File Type: jpg 8801DEDA-4D72-4D05-82A1-08A6A4D7FC8F.jpg (103.4 KB, 30 views)
Hiraga "le monstre" Stefano Solid State 1329 10th December 2015 04:02 PM
Conversion of Hiraga's "Le Monstre" to a Circlotron tiefbassuebertr Solid State 13 30th May 2015 03:31 AM
Hiraga 8W "le monstre" PCB's Tazzz Swap Meet 5 19th April 2015 10:07 AM
Hiraga "Le Monstre" for headphones. owenhamburg Headphone Systems 6 11th April 2013 08:04 PM
hiraga Le monstre moochinazz Car Audio 4 18th April 2011 08:51 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
