DN2540 Power Amp - diyAudio
Old 1st February 2016, 03:26 PM   #1
Default DN2540 Power Amp
So here's what i am thinking:
a single TO-220 DN2540 on a 200v supply. 60-80mA and a 5K:8 transformer load. 10ohm source resistor. Cap across source resistor?
unsure of power output or even if this is feasible?
thoughts?
I am looking to do a small 1 transistor / mosfet amp.
Thanks!
It is not you... you are it.
Old 1st February 2016, 03:40 PM   #2
With 200v supply and 60mA you will fry the Fet; check maximum dissipation.
Don't go beyond some 5 watts of dissipation with a TO-220 part.
Old 1st February 2016, 04:04 PM   #3
The TO-220 has a 15W dissipation limit. If i go to about 75% of that or 10-12W would that work?
thinking 150v supply. 60 mA to 80mA.
If i do 3 DN2540 in parallel.. could use a Edcor 1.25K:8 output transformer. might get 10W output power.
Even with a decent heatsink you would not go above 5W on the 220?
Old 1st February 2016, 04:11 PM   #4
Correct.
Old 2nd February 2016, 01:06 AM   #5
jerluwoo's Avatar
100V@50mA with 1k:8 would get ~1watt of output and be doable for 1 device.
Old 2nd February 2016, 06:54 AM   #6
Elvee is offline Elvee  Belgium
Elvee's Avatar
You could practically reuse this schematic, only a few minor adaptations to make:
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 2nd February 2016, 01:50 PM   #7
Ketje is offline Ketje  Belgium
Ketje's Avatar
Or try something like this
Mona
Old 2nd February 2016, 05:11 PM   #8
on that last diagram... why the diode and zener on the primary of the output?
does anyone have the ability to simulate this circuit?
Old 2nd February 2016, 06:10 PM   #9
Ketje's Avatar
That's to prevent voltage spikes from the OPT destroying the fet.
Same as on the schematic from elvee, but there it is a VDR.
Mona
Old 2nd February 2016, 08:03 PM   #10
Elvee's Avatar
Here is the result, using your data + half-realistic parameters: output power 2W for 3%THD, nominal sensitivity 500mV rms.
Nice harmonic profile, typical of SE (discounting the transformer's distortions).
Note that I find 200V uncomfortably high, but if the DN withstands it, why not.
I kept the dissipation in the DN at <6W, which means R1=27Ω, not 10, but insisting on 10Ω would either mean serious complications or a much higher dissipation in the MOS, none of which is desirable for such a simplistic circuit.
dn2540 noise Celsius Tubes / Valves 5 4th December 2014 09:46 PM
DN2540 croccodillo Tubes / Valves 49 7th November 2011 04:00 AM
6SN7 and DN2540's tmblack Tubes / Valves 11 4th November 2011 01:03 PM
dn2540 chip jarthel Parts 1 1st October 2006 01:51 PM
DN2540 N TO-220 Available dshortt9 Parts 0 15th September 2005 04:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
