Are dual rectifier bridges useful?
Old 22nd February 2004, 03:10 PM   #21
runebivrin is offline runebivrin  Sweden
runebivrin's Avatar
Send a message via MSN to runebivrin
Wow, there's certainly a wealth of information to be found if you're willing to shut up and listen.
I looked into the thread pointed out to me by UrSv (yes, I should've found it myself...), and I must say Fred made a very clear case for how dual bridges can help reduce grounding issues, once I digested the details. From what I understand, this also means a high ESR will contribute a substantial saw tooth ripple as the charge currents get larger under load, which should then cause a greater content of harmonics on the supply voltage, which is more likely to propagate to other parts of the circuit.
On the other hand, low ESR would let the pulse current be greater, which would also cause greater ripple, and also make inductive coupling from the non DC parts of the PSU to the amplifier circuit more of a problem.
Ah well, it sure is an interesting can of worms, once you start getting below the surface...
One of the problems with being an amateur is not having access to particularly exciting measurment tools, so I guess I'll have to take Johns word for the garbage being spewed out by regular slow diode bridges and single bridges. Whether I'm able to hear the difference is another issue alltogether.
Rune
Do wizards use spell checkers?
Old 22nd February 2004, 03:56 PM   #22
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Are dual rectifier bridges useful? Send a message via AIM to Peter Daniel
I believe Fred's thread on diodes was somewhat influenced by my "experimentation" with the sound of different diodes at that time
http://www.diyaudio.com/forums/showt...&pagenumber=52
Not only high speed diodes sound different than regular bridges, but they also sound different from one another, depending on type, rating and even manufacturer.
After many tries, I finally settled on MUR860 in my amp. I was suggested that MSR860 might have been even a better choice, but after extensive listening I found it too bright.
Yet, in my DAC, it's MSR860 that sounds better and actually less bright than MUR860. As always experimentation and listening test are recommended.
Old 22nd February 2004, 11:30 PM   #23
john curl is online now john curl  United States
john curl's Avatar
Peter and Fred, I tend to agree with both of you. Looking at your previous inputs, I am impressed! Fred, your explanation of why we use dual bridges is excellent. I am, of course, not the first to tell you this. Peter, your diode comparison is very similar to what we have found.
Old 23rd February 2004, 09:15 AM   #24
Fred Dieckmann is offline Fred Dieckmann  United States
diyAudio Retiree
Wink Live and let diode
"I am, of course, not the first to tell you this."
But maybe the last I expected to. I will have to keep on my toes if people with the experience you have are going to read my post.
Old 23rd February 2004, 10:33 AM   #25
millwood is offline millwood  United States
Account Disabled
I tried a few soft recovery diodes vs. conventional bridges and I couldnt' hear any differrence.
I am not sure if the whole thing is a fad or what.
Old 23rd February 2004, 11:56 PM   #26
Jocko Homo is offline Jocko Homo  United States
Banned
Why am I not surprised................
BTW, John.............the prices on the really good diodes has dropped over the last few years as they become more popular. Seems that we are not the only ones who now use twice as many as needed.
Jocko
Are dual rectifier bridges useful?Hide this!Advertise here!
2 Rectifier bridges : Why ? Elkaid Chip Amps 85 16th February 2010 02:15 PM
dual rectifier clone.... rtill Tubes / Valves 3 16th February 2009 01:54 AM
dual center tap rectifier replacement dodgerblue Solid State 6 31st July 2006 05:26 PM
Mesa Dual Rectifier Mods...caps? ttrentt Instruments and Amps 9 23rd June 2006 02:39 AM
Can a tube rectifier handle a C dual LC? arnoldc Tubes / Valves 11 11th August 2004 01:03 AM
