Old 20th February 2004, 08:45 AM   #1
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Question DC powersupply +-15V 2-3A
Hello,
I hope this is the right place to ask.
I would like to make a mulitpurpuse PSU for my different small projects.
I need it to be able to deliver something like 2-3 A @ +- 15V
Is this best done by making a positive supply and then "mirror" (NPN->PNP and PNP->NPN) all active devices to make the negative part?
Any help would be great
thanks
\Jens
Old 20th February 2004, 10:36 AM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I'm interested to
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 20th February 2004, 01:03 PM   #3
tcpip is offline tcpip  India
Me too. I've already started a thread on sort-of this issue; see here.
Old 20th February 2004, 05:19 PM   #4
maylar is offline maylar  United States
Default Linear voltage regulators
3-terminal solutions are readily available up to 1.5 amps (LM7815/LM7915 fixed or LM117/LM337 adjustable). If you really need 2-3 amps, you can use the LM338 and configure 2 positive supplies in series for +/- operation. The extra cost of doing it this way is you need separate secondary windings and bridges.
If you want better noise/regulation/precision or adjustable current limiting the regulator of choice is still the venerable LM723. You can use series pass transistors to get any current you want. Again, 2 in series for +/- operation.
It seems that linear regulators are a thing of the past. The major vendors don't list squat any more.
dave
Old 20th February 2004, 06:59 PM   #5
Banned
Send a message via Yahoo to Elso Kwak
Question Re: Linear voltage regulators
Huh,
You must be kidding........
Old 20th February 2004, 09:35 PM   #6
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Linear voltage regulators
Elso, his has a point here if we talk about the general trend but for audio it's a little but hard to make real good SMPS but they are becoming better and better.
BTW: My new revision of my QSXPS has options for more current. I have added the possibility to have external heatsinks and bigger current shunts.
Picture here
/Per-Anders (my first name) or P-A as my friends call me
Old 20th February 2004, 10:26 PM   #7
Default Re: Re: Linear voltage regulators
Originally posted by Elso Kwak
Huh,
There are no negative regulators other than 3-terminal devices any more. National, Motorola and Fairchild all used to have them. Motorola had a +/- 15V regulator chip with a common reference. Not any more. They don't even do linear any more (it's now ON Semiconductor). They also had a floating regulator that I used for HV power supplies (150V). National also had the LM105, which is now discontinued.
Linear power supply parts vendors now cater to low voltage battery monitor crap for cell phones. You can get 3V low-dropout regulators but not +/- 15V chips. That's reality.
dave
Old 22nd February 2004, 06:48 AM   #8
What about the LM317/337? These are easily available where I live, and I don't need adjustable current limiting... just a simple PSU to be used as a building block for preamps and other opamp circuits.
Old 22nd February 2004, 07:38 AM   #9
Banned
Cool Re: Re: Re: Linear voltage regulators
Hi maylar,
There are plenty of positive linear regulators. but you are right about the negative regulators situation as I found out.
Of course the Semiconductor industry is market orientated so there are plenty of options for cell phone circuits with low permissible input voltage.
For higher current and voltage input regulators see f.a.
http://www.linear.com/pdf/ldo_regulators.pdf
http://www.onsemi.com/site/products/...46,250,00.html
http://www.onsemi.com/site/products/...46,366,00.html
http://www.fairchildsemi.com/collate..._pp.pdf#page=1
Old 22nd February 2004, 09:42 PM   #10
Matttcattt's Avatar
i though about building this, but never did. http://sound.westhost.com/project77.htm
i drew (spelling?) a dual version, (attached, i had to squash it ), but i am not sure of its accuracy.
it is 12v, but i think by changing the zener, the volatge could be changed to 15v.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
0-30v 0-10a PowerSupply gev Power Supplies 16 24th May 2006 08:06 PM
PC PowerSupply gev Power Supplies 0 24th July 2005 01:00 PM
Powersupply Kongen Solid State 4 26th October 2003 03:19 PM
Page generated in 0.11380 seconds (79.46% PHP - 20.54% MySQL) with 11 queries
