Hi, everyone,
My beautiful Krell KAV300i has some issue that I hope somebody here can address the problem. Well, I can explain the problem as follows;
1- Amp is on all the input jacks are empty, when I get closer my hands or touch one of the input RCA jacks a very high, annoying hum starts
2- Amp is on and I play something thru one of the single ended inputs without having a problem. But when I switch to an empty input channel that annoying hum starts again and never stops.
This probably happens to be a grounding problem and just have occurred very recently. I have another system using same AC outlet showing no problem at all. I also tried this amp in another room but the problem was still there.
I'd like to have comments on this.
Thanks.
Thanks.
