Topping TP-60 very noisy when connected to DAC (Fixed) - diyAudio
Old 15th January 2016, 05:21 PM   #1
Skree is offline Skree  United Kingdom
Default Topping TP-60 very noisy when connected to DAC (Fixed)
I'm just trying to set up my new Aune X1S DAC/Headamp and Topping TP-60 speaker amp.
When I connect the DAC to the amp, and turn the amp on, i immediately get massive noise, like the hum cheap pocket cassette players used to have when turned up high. It doesn't change if i turn the DAC off, it doesn't change volume when i fiddle the volume on the amp. It's not the RCA lead, i've tried two different leads.
The amplifier uses the 3 pin IEC power connector with ground. However, the DAC has an AC power brick which is a 2 pin plug IE no ground. Is this what's causing the noise? it's all i can think of.
My genius mate gaz got back to me and said "it could be because your USB is referenced higher than ground" which struck a chord because the USB input is from a pc that uses one of those picopsu things. Disconnected that, and it now works fine. Sorry for the needless thread, all
Just hope that a usb lead with the +/- VCCs disconnected fixes it
Old 16th January 2016, 05:36 PM   #2
jaycee is offline jaycee  United Kingdom
You have a ground loop. What kind of PSU does the DAC use ? Is it a switchmode supply, or just a transformer ?
edit: Disconnecting the power connections from the USB port will not work. It is the ground connection, not the +V connection that is the problem, and you have to make a ground connection otherwise the data side of things will not work.
It's also possible that the AC power brick powering the picopsu is to blame. Is that a 2 pin AC connection too ? If so, it is likely that it's ground is floating at half mains potential. Find a 3 terminal (iec or "cloverleaf" mains input) supply to power the picopsu.
Topping tp 21 hixyhicks Chip Amps 14 21st November 2015 06:34 AM
Improving Topping TP 22 niekos Class D 12 9th July 2014 10:22 AM
Topping TP-60 celt Class D 2 23rd June 2014 02:50 PM
Topping TP-60 - help with diagnosing fault achinz Class D 6 25th January 2013 03:28 PM
Topping Tp-30 speakers wahee Chip Amps 0 5th January 2011 03:20 PM
Copyright 1999-2017 diyAudio
