Here's a simple but very good sounding 50 watts amp.
Hello
To keep it simple, there is no CCS and current mirror.
One of the most important section of any amplifier are the VAS (voltage amplification section), that section need to be fast with a low capacitor value. A slow VAS will reduce the slew rate of the amp, meaning reducing the speed of the amp.
The VAS need a fast transistor (the ft), and with a low output capacitance (the cob).
Here's the recommended NPN VAS transistors:
2SC3423 TO-220 ecb, cob: 1.8 pf, ft: 200 mhz
2SC3600 TO-126 ecb, cob: 1.4 pf, ft: 400 mhz
2SC3955 TO-126ML ecb, cob: 1.9 pf, ft: 300 mhz
KSC3503 TO-126 ecb, cob: 2.6 pf, ft: 150 mhz
2SC2911 TO-126 bce, cob: 3 pf, ft: 150 mhz
BD139 are not very good for VAS Transistors, I don't recommend it.
VAS lag comp capacitor for this amp are C12 and the value is 30 pf, too high value will slower the amp.
There is C1, a phase lead capacitor, this capacitor help the amplifier to be more able to drive difficult load loudspeakers, and the value is 6pF.
C11 are the suck-up capacitor between the two drivers, and with R17, it's removes the HF artefacts of the output stage.
R4 are the output offset adjustment, use a 50 k ohm trimpot there, and adjust it for the lower dc voltage at the amp output.
R20 are the bias adjustment, use a 500 ohm trimpot there, and adjust it for a bias of 60 ma for low crossover distortions, R2 are there in case the trimpot become defect.
D2 help to keep the input and vas stage relatively independent from voltage variations from the output stage current demand.
The distortion of that amp are arround .008 %
For best result, all ground should be connect between the two big capacitor of the power supply, look at the image.
I have a limited times to use my low speed internet, so it coud take times for me toreply to any questions.
Bye
Gaetan
have you built this amplifier?
Hi Gaetan, simple is nice. As You already stated, according to Spice, this simple little circuit looks like a good performer
  • Gaetan 50W amp.asc
    Gaetan 50W amp.asc
For the same parts count some enhancements to try:
- Move the RC filter formed by R9 & C5 to the -ve rail, between the VAS and driver stage. The current sources arranged at the top will provide ample filtering (provided the Vrefs are stabilised) and filtering the -ve rail will improve PSR by reducing modulation of Cdom. D2 is probably best omitted.
- Personally I would never put a trimmer in the LTP tail - what if the wiper opens through adjustment or old age? Trimming the LTP tail current this way effects amplifier stability, and you will need to pay close attention to Cdom if you do this. If your goal is to achieve excellent DC offset then simply:
a) make R1 and R18 equal value
b) use high beta and reasonably well matched transistors for the input pair. BC560C (or similar) parts for Q1 and Q4.
c) equalise the LTP collector currents by sizing R14 appropriately. If you a "perfectionist" and really want to aim for 0.0mV offset then this is the place to put the trimmer. On the other hand you can get very good results with an R12 series resistor and excellent results with an R24 one, properly dimensioned.
- You can reduce ripple into the LTP by increasing R27. I would probably make R27 and "VR1" (both fixed resistors) equal value with the decoupler at the midpoint.
The LTP does not need much +ve voltage to operate with very high signal levels.
The feedback through C9 also allows the +ve side signals to go to very high levels.
It's the -ve side that is sensitive to maximum level and determined by the supply rail voltage.
The asymmetical clipping is inherent to the circuit operation and exaggerated by the C9 feedback.
Check that the amplifier exits from clipping cleanly. This is where differences in amplifier sound often come from. How they misbehave has a profound effect on the apparent performance.
Ensure you have sufficient unclipped output such that you never clip any of your audio signals.
20dB of overhead from average level to clipping level ensures that most music is not clipped, but some music/audio types can require 30dB of overhead from average to clipping. And some can manage with only 10dB of average to clipping overhead.
eg 500mW of average signal level into a 86dB/W @ 1m speaker gives you an average SPL of 83dB @ 1m and ~75dB @ 2.5m
20dB of overhead means specifying a 50W amplifier and 30dB of overhead means specifying a 500W amplifier.
Avoid clipping if you can afford it.
Do not go to asymmetrical supplies.
It's normal for your amplifier to have different clipping levels on +ve and -ve excursions.
It is far more important how it comes out of clipping.
Here are a few more "tweaks" to look at.
Reduce R19 and increase C1
Remove D3
Change Q10 to low Cob (Try 2sc3423Y, or even a low Cob To92)
Decrease R8 & R11
Decrease R13 & R22
Decrease R15 & R23
Decrease R4
Decrease C8, massively.
Increase L1, massively.
Add resistor load between Q10 collector and ground. (Try 1k to 2k)
Remove D3
Decrease R8 & R11
Decrease R13 & R22
Decrease R15 & R23
Decrease R4
Andrew, I don't agree with all your suggestions: -
- Q10's collector is grounded, therefore it is not modulated with signal and the Cob is a nonissue. The main VAS transistor should be a low Cob video transistor type.
- Why do you say the driver base stoppers need to be reduced? How much voltage is dropped at full power?
- If the purpose of putting a resistor into Q10's collector leg is for current limiting how big does this resistor need to be to stop it burning up? At a value it is going to be useful don't you think it will adversely affect slew rate?
