Hi all experts and good people !
I have built Holtons scaleable mosfet amp with the good(?) old 2sj55 /2sk175 and it works just great. I am using +-40v. rail supply. Now I wonder if it´s possible to use IRF540 / 9540 instead of the Hitachi mosfet. If it is possible, do I have to change something or, does anyone have a schematic with this output transistors ? Regards, Bengt |
#2 |
The one and only
This subject has come up before in the forum. I suggest you
use the search feature to look for it. In my own opinion, the probable issue is that the bias voltages will be different and you might want to consider the resistance in series with the Sources of the devices for better thermal stability. |
#3 |
I have tried to search the forum but I did not find exactly what I wanted about this. Anyway, I tested to change to this IRF instead and the problem seems to be that I can not bias up the transistors, whit great distorsion on low volume. When I increase the input they draw current and on higher volume they sounds better. Any sugestions ?
Bengt |
#4 |
The Hitachi lateral mosfets have a low transconductance and a low threshold voltage. They are much easier to use in linear applications than the high gm and high threshold conventional power mosfets like the IRF540.
You can make good amps with 540/9540 and similar devices, but the simple biasing used with lateral fets isn't adequate for conventional devices. In most other respects the lateral mosfets are crude, old-technology parts, and for switching applications more modern device structures have replaced them. It's just that for linear amplifiers, where a very low RDSon isn't needed, then lateral mosfets are still better devices for the job. |
#5 |
So, I changed the bias circuit, using a BD139 that I put on the heatsink to prevent thermal runaway and it seems to work very well.
But now I have another (stupid probably) question. Wich way is the best to connect the IRF transistors, the Source driving the speakers or the drain ? I have looked at different schematics where some has the Sourse driving the speakers and nearly the same construktion but swapped N and P channel to let the Drain drive the speaker. Can anyone please explain for me ? Cheers !!! Bengt |
#6 |
The one and only
There are a bunch of topologies out there. Generally, you
are talking about two of the three operating modes - Common Drain, where the Source is connected to the output, and Common Source, where the Drain is connected to the output. Common Drain is used for followers, and they are very linear. Common Source gives you voltage gain as well as current gain, and this has its uses also. Both are effective uses, and are sometimes combined, as in quasi-complementary output stages. In any case, it all depends on everything else..... |
#7 |
I'd leave your design alone. The threshold voltages of the vertical mosfet devices are much higher so you would have to bias them up, and that ends up subtracting from your voltage swing so the power output goes down. The amp would probably sound the same but have less output.
A second consideration is that the tempco of the IRF devices is positive for small currents, unlike the Hitachi laterals at small current. So the output stage would tend to increase bias current as temperature rose, and you would have to counteract that with a current sense on the outputs or some temperature compensation scheme. The lateral devices are much more appropriate for this type of audio amp design for that reason alone. I actually did what you're saying to an old Dynaco 400 about 6 years ago. Here there is a benefit, since you don't have to cascode the output stage for second breakdown prevention (the wasted swing due to cascoding was about equal to the wasted swing due to higher bias voltage). I think I had about 4-5 volts of bias, and tried to track temperature with the Vbe multiplier on the heatsink. I used a TO-3 packaged device, the IRF130 and 9130 as I recall, to make the switch easy. I had numerous problems specific to mosfets, such as a high-frequency parasitic oscillation due to the lack of proper series resistances in each gate drive. Once I got the bugs worked out, it was and is a good high powered amp. Overall the output stage was much simpler than the original, and far more rugged. A good use for old iron..... |
#8 |
Thanks for your reply!
I am not an expert in this area but I am very intrested and want to learn "everything" to make constructions. What I did is this: I have the Scaleable amp from Holtons site that I made with Hitachi K175/J55 that I had from "back in time". The amp works just great, with no problems and a great sound ( I took it to the lokal HIFI store and they where impressed of the sound.... hmmm). Then I wanted to see if this could work with the IRF HEXFET instead, mostly because of the price difference and that the Hitachi is old and so on. So, instead of a simple pot between the Gates to bias (this did not work good) I putted a BD139 and 2 resistors paralelt with the pot to increase the bias ro the IRF and, to make a thermal connection to the IRF so the BD139 would prevent thermal runnaway. I would like to show the schematic here BUT, because the half construktion is Holtons, I think I can not. So, the amp runs good, without any thermal runnaway but the sound from it is not the same as with the Hitachi MOSFET, they give a smooth and warm sound and the IRF gives a hard and...... difficult to explain really. I think that I have to do some changes in the circuit to get "better sound" but I have not figured out what to do yet. just continue working...... Regards ! Bengt |
#9 |
The one and only
Good for you!
I think you could safely post the output stage and bias, since that is not Holton's. Probably more bias is called for on the sound issue, and usually fewer devices is appropriate, but the heat issue might not allow for this in your amp. Also, you don't mention Source resistor values, and you'll definitely need some, say at least .47 ohms. |
#10 |
Here is the output stage. I putted 0.27 ohm as source resistors and I biased up to approx 150 mA on each rail with +-35 volt. Before I did not put the BD139 on the heatsink , I could see that it had some thermal runnaway because the amp was increasing within the heat of the IRF but when I putted the BD139 together with the IRF it seems to be stable and decrease the bias when the heatsink gets warm.
Bengt |
| IRF540/9540 or IRFP240/9240 | Ermac | Solid State | 18 | 13th January 2012 01:06 AM |
| On IRF540/9540 | Hans Olofsson | Solid State | 40 | 21st October 2007 07:00 PM |
| Bridge With IRF 540 & IRF 9540 | myanmar | Solid State | 63 | 17th November 2006 12:17 PM |
| WTB: IRF540 and 9540 fets | demogorgon | Swap Meet | 21 | 1st October 2005 03:46 PM |
| IRF540/9540 or IRFP240/9240-power,better? | zox2003 | Solid State | 3 | 25th March 2005 10:11 PM |
| Page generated in 0.15623 seconds (68.51% PHP - 31.49% MySQL) with 11 queries |
