Pioneer Sc-09TX - diyAudio
Old 20th December 2015, 04:01 PM   #1
Tom7227 is offline Tom7227  United States
Tom7227's Avatar
Send a message via AIM to Tom7227
Default Pioneer Sc-09TX
Looking for an experienced person for troubleshooting this amplifier.
When the power button is pressed, the amp turns on, stays on for about 10 secs, then shuts down.
The Phase control indicator flashes, and that's it. The service manual states that an overcurrent was detected.
I went thru the painstaking dismantling process and determined that none of the amplifier outputs are shorted.
The Icepower supply itself turns on if you run 120vac directly to it. I think the supply voltage is 141vdc. All appeared fine.
I can't find what senses the OC, any help would be appreciated.
Old 20th December 2015, 05:07 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Have you service manual? Check for DC on the outputs and any rail that doesn't appear at switch on.
Support for Flying Mole Class D, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Pioneer sc-lx71 blowing fuses mralfagt Solid State 36 28th May 2015 06:15 PM
Your Toughts On Pioneer Elite SC-57 2MuchRiceMakesMeSick Class D 1 28th October 2011 10:18 PM
Help With Pioneer Elite SC-57 - Output way too low 2MuchRiceMakesMeSick Class D 4 22nd October 2011 02:19 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
