Looks like measurement grade onboard audio, or something not very far from it... the 0.05-ish dB periodic ripple is telling. Good enough, anyway.
I think the idea would be comparing a straight loopback vs. a detour over -80 dB --> LNA. (The ground loop may need to be taken care of.) At least I'd expect much better accuracy from that when compared to using the signal generator as a source. You should have 20 dB of difference, pretty much all the rest is your gain error.
Thx. Let's continue this part of the conversation in the Groner measurement amp thread as it is more appropriate place.
SGK, do you by any chance have the dimensions of the input stage? Given that you seem to have had the some holes drilled (#146).
http://www.diyaudio.com/forums/soli...ty-gain-balanced-input-stage-post4807633.html
Looking through this thread, I noticed this:
I just remember Douglas Self's capacitor distortion test, and some of the (film) caps peaked at 400Hz. So, I think a mild improvement might be accomplished by using different capacitors. Any opinions on this?
The lowest result was -84.41dBV @ 8kHz while the highest was -80.76 @ 400Hz. The average was -82.00 dBV.
LME49740 replacement - Audio forum - Audio - TI E2E support forums
https://www.ti.com/product/OPA1604
Not tested etc but found the reference and thought it useful to post it here
- Self's "5532 Low Noise Unity Gain Balanced Input Stage"
