It was quite common in equipment designed in the 70's and 80's. At some point, opamps became cheap enough that most people went the opamp route.
www.akitika.com
www.akitika.com
Perhaps because the CFP is best used as an improved emitter follower.I see CFP/Sziklai Pair used in output stages all the time but much less elsewhere. Is there a reason for this?
Output stages want improved emitter followers. Previous stages don't want or need emitter followers nearly as often. However CFPs do find application in bias spreaders / VBE multipliers, where their quadratic current gain is useful in reducing the end-to-end impedance, deltaV/deltaI.
Joined 2009
I've tried the cfp in most places in an amp.
In the input stage it always sounded harsh, couldn't get along with it.
In the VAS I had mixed results - once it was OK, the other time it was not nice.
In the output stage I've used it single ended (headphone amp) and push pull (power amp) and liked it a lot, even at low power.
You might have seen this Thread about Preamp Buffers that deals to a great extent with CFP structures.
From about #52 on (and #87) the circuit basically reached its final design.
The CFP functions very well also in I/V converter stages as grounded base Input stage.
It keeps the input impedance very low and constant over frequency.
You may also search for user WrenchOne´s threads and posts (#51 e.g)
He used CFPs as gain stages also and his posts are generally a fine read.
jauu
Calvin
jauu
Calvin
CFPs can be used as an improvement on a Darlington pair when you need a simple buffer, but they need to be properly designed as the improvement is only seen at medium current levels. Current too small and the CFP doesn't really work; current too large and it is no better than a Darlington at the same current - and probably less stable.
Degeneration (feedback) is needed with a current feedback pair. The overall Gm is quite high even for small signal devices in this arrangement. Degeneration should be relative to the particular transistor in question and relative to it's re; linearizing overall GBW and setting a limit to output goss. Playing with the amount of degeneration for a particular situation might yield you interesting results.
That's a keeper, thanks! Putting it on the list of DIYA howlers, right now.... linearizing overall GBW ...
That depends on the value of the resistor across the base-emitter of the second transistor. You need enough total current that the second transistor has turned on, but not so much that the second transistor base takes nearly all the current (as then you might as well use a Darlington).mrkramer said:What would you consider small current?
- small signal cfp?
