Adding NPN-PNP Transistors with TDA7377 ?? - diyAudio
Old 18th December 2015, 02:43 PM   #1
ToFa is offline ToFa  Bangladesh
Send a message via Skype™ to ToFa
Red face Adding NPN-PNP Transistors with TDA7377 ??
Hi
I have TDA7377 Chip Amp.
I also have some TIP41C and TIP42C NPN-PNP Transistors. They are lying idle. So I want to use them. I was thinking if I can use them with my Chip Amp, that would be great!
But I don't even know how to use those Transistors
Here I attached TDA7377 functional diagram and its Output stage schematic.
If any expert of you can help me with these...!
sorry, I'm not good at English
Thanks in advance..
Old 19th December 2015, 11:22 AM   #2
no reply
plz just tell me anybody if it's possible..!!
Old 19th December 2015, 12:51 PM   #3
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
Without proper biasing, there will be extreme distortion and possibly damage to the new transistors and the TDA7377.
Support for Flying Mole Class D, Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 19th December 2015, 08:21 PM   #4
can u make me a circuit with proper biasing?
Old 19th December 2015, 08:31 PM   #5
I think that it would not be advisable with this particular amp since you have no access to the negative feedback loop on two of the sections.
Just study up on the Current Boosted Opamp configuration for more info.
https://www.google.com/search?num=10...59.6tJyvE0xVkQ
There are quite a few threads already on this subject in this forum.
Cheers!!
jer
Here is a little Project that I did that used similar transistors and it worked Great !!!
opamp plus driver stage and output stage with its own supply, what could happen?
Old 20th December 2015, 04:44 AM   #6
thank you
I'm studying on it :3
Matched PNP/NPN dual transistors carlmart Solid State 32 22nd January 2016 08:03 PM
Types of transistors pnp npn? realflow100 Solid State 23 10th October 2013 03:17 AM
Amplifier NPN+PNP Transistors Tester Circuit lineup Solid State 4 1st March 2013 03:17 PM
PNP NPN Complimentary Transistors dannywhac Parts 2 20th August 2009 06:23 AM
Use of PNP transistors instead of NPN in buffer circuit. TB Chip Amps 13 8th October 2007 06:58 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
