Tripath worth my time? - Page 2 - diyAudio
Old 24th May 2001, 03:43 PM   #11
hifi is offline hifi  Sweden
should i even consider a digital amp it sure as hell must have spdif input...it would be stupid to convert the signal from analog (recording) to digital (cd) to analog (dac= to digital (amp) and once again to analog (speaker)......
IMHO ofcorse....
/micke
Old 25th May 2001, 03:12 AM   #12
e_fortier's Avatar
Smile National IC's
Maybe you should try using IC's from National, they have pretty good power amplifier IC that you could bridge to obtain greater power. By bridging 4 x LM3875 or LM3886 you could get up to 200 W in 8 ohm.
Good luck
Eric
Old 31st August 2001, 06:26 AM   #13
Default re tripath
It can't be that bad. The fact that belcanto uses this chips in the evo series amps( with rave reviews I might add) is significant for me. Especially because this is a company with a rich history of good tube/analog sound. The sell the chips on the high end for 38 a pice or you can buy the developers kit ( basically a built amp board sans power supply) for 300 USD for the top of the line one. I plan on building one as soon as I can find a kit or get some good board designs done. Hope this is helpful
Old 9th September 2001, 06:15 PM   #14
km is offline km
Smile tripath boards
hi.
we have the boards and the chips available (not much idea in making one board i think).
let me know if you need a board and / or more info.
bye k madsen - http://www.cadaudio.dk
Realistic Solo 4b worth the time? KT Full Range 0 5th April 2008 02:56 PM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
Is this worth my time? EricR Tubes / Valves 11 16th September 2004 06:49 PM
is doing time alignment now a waste of time? Beggar Multi-Way 9 28th July 2003 05:45 AM
Does it worth it?? gretzteam Multi-Way 3 21st January 2002 05:55 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
