Replacing power supply capacitors
Old 13th October 2009, 04:17 PM   #11
djfoundation is offline djfoundation  United States
Originally Posted by DRC View Post
If you do replace caps, be sure to get caps with a rated temprature of 105 rather than the normal 85. They are bigger and more expensive to buy but will pay for themselves in the long term.
D
^^ Agreed. Any time I recap anything for friends, I look for hi temp, low ESR standard audio caps. Nichicon is what I usually end up buying.
also, I'm close to Digi-key too, but often opt for Mouser simply because they don't tack extra handling fees onto small orders like Digi-Key does.
Old 14th October 2009, 12:35 AM   #12
tuanloinoel is offline tuanloinoel
Thanks you all for your kind advice which I found very helpful. With regards to rectifier, can you recomend a good brand?
Old 14th October 2009, 09:21 AM   #13
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
I work in most cases with Semikron rectifiers, e. g.
SEMIKRON - IGBT, Diode, Thyristor, Power Semiconductor Modules, Chips, Assemblies
or IXYS (e. g. VBO22-16NO8, diode bridge)
http://ixdev.ixys.com/DataSheet/VBO22.pdf and a delivery source:
DIODE BRIDGE 17A 1600V FO-B-B - VBO22-16NO8
Old 16th October 2009, 01:42 AM   #14
Thank you so much Tiedfbassuebertr for your very detailed and helpful advice.
Replacing power supply capacitorsHide this!Advertise here!
Power supply capacitors gehlhoff Solid State 7 12th February 2012 11:02 AM
Power supply Capacitors Vivek Solid State 59 28th February 2008 07:11 PM
Replacing meters in bench power supply artb Parts 2 20th August 2006 11:19 AM
Power Supply Capacitors awhiteguy Parts 27 22nd November 2002 10:40 PM
Power supply capacitors wchick Pass Labs 12 12th August 2002 05:26 PM
