Old 16th February 2004, 04:24 PM   #1
K-amps is offline K-amps  United States
K-amps's Avatar
Question Class-A calculations
Based on a few responses on the forum, I rigged an excel sheet to calculate the class-A output using variables like number of devices, emitter resistance value, voltage drop across the emitter resistors, DC rails and came up with the following:
Class-A output Calculation: (Nakamichi PA-7)
Inputs
Number of output devices: 7 Pairs
Voltage rails (per rail): 70 volts
Emitter resistance (per device): 0.22 ohms
Bias voltage per Emmiter resistor: 32 mv
Speaker ohms 8 ohms
Results
Idle bias per device: 0.15 Amps
Total Amplifier bias (both rails) 2.04 Amps
Total Dissipation (per channel) 142.55 Watts
Class-A output: 50 watts
Does this look correct? because for the Adcom 555II at factory biasing, it comes out to be 11 watts class-A... Is that probable?
Adcom GFA-555II.
Number of output devices: 4 Pairs
Voltage rails (per rail): 82 volts
Bias voltage per Emmiter resistor: 10 mv
Speaker ohms 8 ohms
Results
Idle bias per device: 0.05 Amps
Total Amplifier bias (both rails) 0.36 Amps
Total Dissipation (per channel) 29.82 Watts
Class-A output: 11 watts
Have I done this right? Any thoughts are welcome.
-K.
Old 16th February 2004, 04:57 PM   #2
Account Disabled
Default Re: Class-A calculations
-K.
the "class a" current swing would be from +2amp to -2amp. the peak power output on an 8-ohm speaker would be 2^2*8=32w. RMS is 50% of that, or 16w. so that's not too far from the factory claim of 11w.
now, if their calculation is off 6-ohm speakers, then it would be 24w peak and 12w rms. even closer.
Old 16th February 2004, 05:11 PM   #3
K-amps's Avatar
Millwood,
The 11w figure (for the Adcom) is not a factory claim. It 's the calculation I arrived by using the factory specified 10mv bias voltage across the 0.22ohm emmiter resistors with 82 volt rails and 4 complementary pairs in outputs.
The 2.04amp number was for the Nakamichi PA-7, in which case:
I calculated by taking total amplifier bias current (in this case one channel) multiplied by Dc rails 2.04*70= 142.8 peak watts dissipated. i.e. 71 watts per rail (1.02amps) and the RMS value for this 71 watts is around 50 watts.
My question is did I calculate this correctly?
thanks!
-K
Old 16th February 2004, 05:19 PM   #4
Account Disabled
well, then, we have a problem,
7 pairs x 0.15amp = 1amp (give or take a few hundred ma).
Into 8ohm load, that's peak power of 1amp^2*8ohm = 8w. or rms power of 4w.
total dissipation per rail is 1amp*70v=70w. peak dissipation on the transistors happens when there is no signal. lowest (class-a) dissipation on the transistors happens when output 1amp. at that point, it is 1amp * (70v-8ohm*1amp)=62w.
you can do that math with the adcom as well. but my numbers are: peak class a output power 0.36amp^2*8ohm=1w (close enough). total transistor dissipation per rail is 82v*0.36amp=30w.
Old 16th February 2004, 05:31 PM   #5
K-amps's Avatar
Thanks Millwood I think we are getting somewhere. Some more questions: My descriptions may be misleading so let me try again.
1) 7pairs * 0.15amp is 2.1amps (because the 0.15 amp is per device not per pair). Would your calcs still hold true. What I would get based on your calcs is:
7 pairs x 0.15amp = 2.1 A
Into 8ohm load, that's peak power of 2.1^2*8ohm = 16.8 watts or rms power of 8w. ?
2) By the same token the dissipation would be 2.1A* 70v= 147 watts.
3) Conventional wisdom says that for each 1 watts of class-A, about 3 watts are dissipated as heat (in case of a push-pull design) therefore would'nt that be more in line with my calucation of 50 watts of class-A for 147 watts of dissipation?
Please bear with me here!!
Old 16th February 2004, 06:01 PM   #6
Account Disabled
"7 pairs" means to me 14 devices: 7 of them on the upper side and 7 of them on the lower side. so total idle current from the upper side is 7x0.15ma=1amp. the same is true for the idle current on the lower side.
the 25% efficiency is for SE class A driving a current source. not that applicable here.
in your case, each rail is supplying 70v (for Nak) and 1amp. so it is 70w each rail and 140w total (for both rails).
Old 16th February 2004, 06:10 PM   #7
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
A pair means one device for sourcing current and other sinking it, isn't it?
With 0.15A per device, total current being cross-conducted between positive and negative supplies would be 7*.15 = 1.05 A
With a resistive load and 0V output we are sourcing 1.05A and sinking 1.05A so there is no net current available to the load
The principle of operation of complimentary class A is that as current sourcing from the upper devices increases, current sinking from the lower devices decreases by the same magnitude [and vice-versa]
If we want the output to source 0.5A, then the upper devices will have to increase its conduction by .25A and the lower devices will have to decrease it by .25A [and vice-versa] to provide a current difference of 0.5A
If we want 2.1A to be sourced, then the devices on the upper side would have to increase its current by 1.05A [giving a total of 2.1A] and the devices on the lower side would have to decrease its current by 1.05A [giving a total of 0A and geting out of class A zone]
So with 1.05A bias actually we have +-2.1A output swing [this is the cool thing about complimentary class A, it has double the efficiency than single ended class A]
With +-2.1A into 6.4 ohms [typical Re of most 8 ohm drivers] we get 13.44V peak that on 8 ohms give 11.3Wrms
Old 16th February 2004, 06:10 PM   #8
Hi Guys!
I think you are both missing one point.
The definition of class A is that always NPN and PNP
remain conductiv.
Let's calculate it for 2.1A idle current and a 8Ohms speaker.
The output current is difference between the current in the
upper and lower transitor (sum of all currents into one node
is always zero).
At zero A output the upper transistor will push 2.1A into the
node, the lower will push -2.1A into the node (means it pulls 2.1A from the node). 0+2.1A-2.1A=0. Fine.
Let's go on. 2A into the load. This means the upper transistor will have 3.1A (2.1A idle + half load). The lower transistor will have 1.1 A
(2.1 A idle - half load).
The sum in the output node:
3.1A is delivered from the upper, 1.1A is drawn from the lower,
2A are given to the load.
Still both (NPN and PNP) transistors are conductive.
The limit of class A will be when the lower one get no current
any more. This is reached at 4.2A in the upper, 0 A in the lower
and 4.2A into the load.
So the traditional limit for class A is reached, when the
peak value of the output current is twice of the idle current.
I am not sure if I understood your particular design right,
I would think the following.
4.2A peak into 8 Ohms, makes 141W peak or about 70W rms
The total heat dissipation would be 2x70Vx2.1A=294W!!!
If I understood right that you are working with rails of
+/-70V, right?
If this true, then this Amplifier will have a good power margin above
its class A range. Class A will end at about 33.6V peak, but
the amplifier can probably deliver up to more than 50Vpeak (depending on the saging of the rails...).
Looks like you are having a real Monster with you!!!!
The Adcom will only have a very low power range in class as
its idle currents is only 200mA....
...hope I did not add more confusion to this forum..
Markus
Old 16th February 2004, 06:12 PM   #9
Hi Eva!
Ok, you win. Ladies are simply faster
Old 16th February 2004, 06:16 PM   #10
...still interested if your Amp really has 7 pairs for each chanel...
meaning 2.1A idle in each chanel...?
meaning around 300W heat per chanel...?
Is it a Monoblock?
If the 7 pairs are for stereo... how would this work.
left chanel 3 pairs??!!! right chanel 4 pairs?.!!
Would not sound reasonable....
need help with TL calculations jmillerdoc Multi-Way 51 16th April 2009 03:56 PM
Mms to Mmd calculations jaya000 Multi-Way 2 9th February 2009 07:48 AM
BIB Calculations davidallancole Full Range 44 11th March 2007 03:04 PM
Torroid Calculations Question. (And Class) Macaba Chip Amps 19 13th January 2006 06:09 PM
calculations lXxAndyxXl Multi-Way 8 19th October 2004 04:53 PM
Page generated in 0.14827 seconds (74.49% PHP - 25.51% MySQL) with 10 queries
