What does it mean by "leaky"?
Old 6th December 2015, 01:28 AM   #1
kuer is offline kuer  Canada
Default What does it mean by "leaky"?
If somebody says these output transistors got leaky, does it mean something like liquid coming out of the transistor? or any other meanings?
Actually I checked my transistors, it looks perfect physically.
I need some advice.
Thank you very much.
Old 6th December 2015, 01:30 AM   #2
DPH is offline DPH  United States
Can you give a more clear example of what you're asking?
The closest thing I can get to your question is gate leakage on a MOSFET.
Happy DIYing, Daniel
(This space is occupied by the artist formerly known as Derfnofred)
Old 6th December 2015, 01:41 AM   #3
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
I believe you're referring to the propensity of early semiconductors, particularly germanium, to pass some current when they're not supposed to, it has nothing to do with physically leaking fluid or anything else. Modern semis don't have this issue.
Mike
Old 6th December 2015, 01:44 AM   #4
rayma is offline rayma  United States
That refers to current, not fluid. When p-n junctions are reverse biased and should be off, they have a certain small "leakage current"
that can drastically increase with damage, or improper operation.
Old 6th December 2015, 01:47 AM   #5
Thank you for your quick reply.
My marantz receiver 2235b works, but only for 20mins from cold start, it is overheated on the heatsink. If I don't close the cover, seems working with no issue.
Found that one of output transistors is very hot. now I am buying new transistors, not received.
Actually I measured all transistors, should be good according to the testing method.
Checked online, somebody says the transistor is "leaky", don't undersand this word at all.
Old 6th December 2015, 01:52 AM   #6
Yes, thanks. another issue is that when turning on or off, there is a pop sound on one speaker, guss the same cause. First step, I will replace transistors.
Old 6th December 2015, 01:53 AM   #7
Kuer--I think the other two posters are going to get you along the right direction. Sounds like there's a bias problem (which would mean that the output transistors are conducting beyond what they normally should, i.e. leaky)
Old 6th December 2015, 01:56 AM   #8
The problem is that the bias cant be adjusted much, very high voltage, forget it. No way to adjust correctly.
Old 6th December 2015, 01:56 AM   #9
Mike
Ok, thanks, understand this. thanks.
Old 6th December 2015, 06:16 AM   #10
Enzo is offline Enzo  United States
There is the measure of the normal leakage current as described above by others. But a transistor can also fail in a way that allows current to flow when it should not, and we refer to that as a leaky transistor.
What does it mean by "leaky"?Hide this!Advertise here!
speaker for a "leaky" enclosure ? gougigaga Full Range 17 27th August 2014 12:08 AM
The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter River757 Multi-Way 16 8th July 2013 01:45 AM
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 01:43 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Bass driver behaviour in "leaky box" FE3T Car Audio 1 28th July 2009 09:23 PM
Copyright ©1999-2017 diyAudio
