Loudspeakers dc protection - question about caps suitability - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Old 6th December 2015, 01:03 AM   #1
00940 is offline 00940  Belgium
Default Loudspeakers dc protection - question about caps suitability
I'm planning to use a loudspeakers protection pcb based on the esp 33 project.
The project uses 10uF bipolar caps after 100K resistors as input filter. Would there be any downside in using 10uF/25V X7R caps in that position ?
There's little AC at that point (max 250mV at 20hz) and little dc too (max 2.5V).
Ben.
Old 6th December 2015, 09:40 AM   #2
Don't use X7R for signal duty.
They are ideal for local decoupling duty.
The 100k separate the distorting effect of the ceramic from the previous audio stages, but I would not.
You will find that the DC detect circuit works with a very wide range of filter turn over frequencies.
Try increasing the 100k to 330k and reducing the 10uF NP to 1uF, or 2u2F, or 3u3F plastic film. MKT/MKS is OK.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th December 2015, 10:35 AM   #3
I wouldn't use X7R for coupling duty. But this filter is hardly critical. The normally used bipolar cap isn't exactly a precision cap.
The datasheet isn't very explicit however on the variation of capacitance vs AC/DC signals. They only give two curves, for DC with a 01uf/50v cap and for AC with a 10uF/6.3V.
- I'm not too worried about DC: under 20% of the voltage rating, the capacitance is apparently equal to the nominal value. So that's fine.
- The variations with AC signal are more drastic. But is there a way to extrapolate what it would give in this particular situation and with a 25V rated cap ? If the variations are in a +/-10% range, it's fine.
PS: caps are grm31 from murata.
Ben.
Old 7th December 2015, 11:25 AM   #4
Murata has quite an amazing website when you start digging into it.
I've browsed through their detailled specs and the 1206 x7r 10uF/25V has pretty poor AC voltage characteristics. They however have a 1210 x7r 10uF/35V which is really pretty good. Considering those graphs, I see no reason not to use the 10uF/35V. Well, there's one: the cost is the same as a 3.3uF wima mks.
The 25V:
The 35V (GRM32ER7YA106KA12):
Ben.
Old 8th December 2015, 02:05 PM   #5
Unless you are placing the cap. near a heatsink, what's the problem with an economical BP electrolytic? It's not a critical performance item, so what are you trying to do - SMD only or everlasting parts? I can't see the point as these will outlast 99% of DIY projects.
Ian
Old 8th December 2015, 03:51 PM   #6
Small bipolars aren't stocked by the suppliers I use for most projects (Reichelt). It's more a question of convenience and avoiding extra shipping charges.
Ben.
Old 8th December 2015, 04:03 PM   #7
Bi-polar electrolytics only come in small values,
typically 1uF to 470uF.
Try a different retailer.
regards Andrew T.
Old 8th December 2015, 04:23 PM   #8
Which is exactly what I want to avoid.
Ben.
Old 8th December 2015, 04:29 PM   #9
then try using back to back and/or front to front polar electrolytics.
They are not quite as good, but they are far better than many here allege.
I think it is Marsh that did distortion comparison measurements of polars, bipolars and back to back versions.
I also tried a back to back pair in parallel to a front to front pair.
4 off 10uF give a good 10uF bipolar, that when there is no AC voltage and no DC voltage across them, creates no distortion of the wanted audio signal.
I could not tell there was a capacitor in the circuit.
regards Andrew T.
Old 8th December 2015, 04:33 PM   #10
What is the relevance of distortion in this case ? I'm not designing a servo or an audio filter. As long as variations in capacitance are kept under +/-10% in the operating conditions of those caps, the filter will fullfill its role.
Ben.
PPI pc6600.2 DC offset protection circuit info question socaler Car Audio 9 17th May 2014 10:30 AM
Combined DC protection and tweeter protection? CopperTop Solid State 10 13th January 2011 08:52 AM
Lotus BVR/CHR-70 - Question about suitability BL21DE3 Full Range 37 3rd January 2010 01:55 AM
dc loudspeakers protection cld1354 Chip Amps 6 6th September 2003 09:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
