Audiolab 8000a Amp Left Channel Crackling - diyAudio
Old 4th December 2015, 11:20 AM   #1
Default Audiolab 8000a Amp Left Channel Crackling
The left channel of my Audiolab 8000a has recently developed an intermittent cracking sound which seems to be getting worse.
The crackle happens when the amp is left alone, but also when the case it touched. It happens on all input selections, when the volume is off and from both left channel outputs.
I've opened the amp to have a look and the crackle also occurs if I make contact with the board or a component with a plastic probe.
Does anyone know where I should start to diagnose this problem.
It would be great if this is an easy-ish fix!
Thanks for the help.
Old 4th December 2015, 11:35 AM   #2
It is probably ageing capacitors.
Try replacing all electrolytic capacitors, this will probably improve the sound too.
Old 4th December 2015, 12:36 PM   #3
Mooly's Avatar
That sounds like a dry joint somewhere, particularly as you can provoke it by physical means.
Give the board a good visual look over, in particular look over any parts that run hot. This would be a typical scenario, the solder around the transistor leads is cracked.
Installing and using LTspice IV. From beginner to advanced.
Onkyo TX-2000 with STK463 - crackling in left channel kstinmb Chip Amps 1 10th May 2015 02:54 AM
Crackling noise from left channel of my Arcam CD23 andy2 Digital Source 8 7th March 2013 05:14 PM
Crackling sound from left channel of X150.5 pingpong Pass Labs 1 7th February 2011 03:14 AM
Crackling noise in left channel. fritz39 Solid State 1 21st January 2009 12:57 AM
Tube Amp - Crackling Sound on Left Channel Noak Tubes / Valves 8 28th December 2005 02:46 AM
Copyright 1999-2017 diyAudio
