Pioneer SX-838 -- random no sound output, clicking relay
Old 25th February 2004, 05:26 AM   #11
Symx is offline Symx  United States
This Problem is common on all older Pioneers. The PNP Diff amp transistors in the poweramp section, should be changed as they go intermittant quite often. Another common problem is in the protection circuit itself. Several of the detector transistors start to leak and force the unit into protect. Of course you should measure the amp outputs for DC to verify wich problem you have.
Old 26th February 2004, 12:12 AM   #12
VTbimmer is offline VTbimmer  United States
Hmm ok I think I have found the problem.
On the Protection circuit board, there is a transistor (or a diode? I don't know the difference) which is connected to the ground side of the relay operation circuit. If I just two of the legs of the transistor, I can make the relay click closed, creating the circuit to let the speaker singnals through to the speaker connections.
It looks like the board has been repaired before, as the bad transistor seem to be different that the other ones on the board. There are newer solder points on the bottom as well.
I am not positive that this is the problem, but as long as I have the jumper wire in place, everything works perfectly.
Here are the numbers on the thing...where can I find a replacement?
C1383 R .74
Thanks for the help
Kevin Elmore
Pioneer SX-838 -- random no sound output, clicking relayHide this!Advertise here!
Zenith K731 AM/FM radio audio random cracking sound in FM mode AC439 Tubes / Valves 15 20th February 2009 09:06 PM
nakamichi cd 700 clicking sound plz help !! anton-sa Car Audio 3 22nd December 2008 05:10 PM
nad 3020 clicking sound when playing islanddancer Solid State 16 13th September 2008 06:33 AM
across my output relay is ............ Pbassred Solid State 11 21st January 2008 10:32 AM
CLICKING Sound when spinning CDs on Pioneer DV-575A ,HELP...laser or what??? stifa Digital Source 6 24th November 2007 01:07 AM
