I have found this schematic of a 150W amp
What do you think about that? Is a good amp? ------------------------------------------------------------- This is one small description that I have found: A really good amp with an outstanding bandwidth of 1.55MHz and slewrate of 80V/us Output transistors have been changed to a type that can handle more power. Also there has been added a separate powersupply for the input stages. This will increase power output for a given supply voltage significantly. A good tip is to separate powersupply for the input stages. You can just run the two powersupply inputs in parallel, and build a separate powersupply for the input stage in the future to acheive a higher power output. In any case the supply voltage for the input should be min. 5 Volts higher than for the output to acheive any real power increase. Run into a 4 ohm load the 150W amp will produce about 300Watts of continous output power. A really excellent amplifier! ----------------------------------------------------------- Components: 0,33Ù 9w R27-R30 1k Ù R1 2k Ù Pot2 2N5401 T3-T5, T7 2N5551 T1, T2, T6, T8, T9 2SA1358/MJE350 T11 2SA1553/2SA1943 T16, T17 2SA1837 T13 2SC3421/MJE340 T10 2SC4029/2SC5200 T14, T15 2SC4793 T12 3k9 Ù R17 4,7ìF poly C2 4k7 Ù R12, R13 10k Ù R3 10Ù R5-R8, R31 15nF C10 15pF C7, C8 47Ù R23-R26 47ìF 25V C9 47ìF/100ìF 63V C3, C4, C11-C14 100k Ù R2 100Ù R21, R22 100pF C1 200Ù Pot1 220Ù R19, R20 330k Ù R4 330nF C5, C6 390Ù R14 470Ù R11 560Ù R18 680Ù R9, R10 Red D1, D2 100Ù R15, R16 regards D.N. |
#2 | |
Very similar to the Rotel RB 980 BX...yes!! ....it's a good design! It's a inverting amp!
Jorge |
#3 |
Good design but Inverting!
Excellent Current Amplification Factor using TRIPLET TRANSISTOR CONFIGURATION. Regards AmPmAN
#4 | |
Just some minor points:
No protection against capacitive loads, either a series resistor or an inductor, stability into these loads could be an issue. (may be off the page to the right) If seperately rectified and smoothed IMO the complication of providing the extra 5V for the 60V rails is not worth the effort, unless you can easily find a transformer with the right windings. . Quote:
(Balancing of the input stages and VAS current value looks indeterminate to me.) |
#5 |
There is a problem; in the schematic R15,R16 are 47Ohm but in the component list them are 100Ohm
Which value is better? Regards D.N. |
#6 | |
A inductor or resistor at the output allways cause some sound quality degradation.. By the way ...the similar Rotel doesn't also use output inductor ( if memory serves) ![]() About the VAS current value indeterminated... The current in the LTP is defined by the CCS and cause a voltage drop in the colector resistor...this voltage drop define the voltage of the base of the VAS transistor...and that voltage define de current in the VAS by action of the emiter resistor of the VAS. So i don't see any reason for this current to be indeterminated. This kind of VAS biasing is a typical one!
Jorge |
#7 | |
Jorge |
#8 | |
#9 | |
If they used it....my memory is not what it used to be... ![]() Naim also use a resistor ...0,2 Ohms i think.
Jorge |
#10 | |
in the LTP's or vice versa, neither the current sharing or VAS current is fixed as I see it, which is why I said indeterminate. |
| How to minimize 150W amp to 25W | ro9397 | Pass Labs | 1 | 2nd October 2007 04:41 AM |
| F/S 150w MH ballast | phaze5 | Swap Meet | 5 | 26th April 2003 06:56 PM |
| Page generated in 0.13197 seconds (79.21% PHP - 20.79% MySQL) with 11 queries |
