#81 | |||
Yes, the two sides of each LTP have equal current for minimum open loop distortion. Quote:
in the same direction, so Iq's are equal, I still cannot see how each LTP is forced to be balanced. As I said above slightly rephrased: Quote:
#82 | |
How both LTP could be unbalanced in the same direction? Remember that upper lower bases are tied toghether, current sources are of the same value and transistors/resistors are matched by pairs like in a single ended LTP To get noticeable unbalance in the same direction you need severely unmatched Vbe or resistors [In a single ended LTP with a current mirror you would get severe offset in the same unmatched conditions] |
#83 |
Overall feedback ensures current balance...if not ,a large DC ofset will be displayed at the point of connection of the two colectors of the VAS.
Jorge |
#84 | |
VAS base-emitter to ground. Lets say Vbe of VAS = 0.7 volts. Lets assume a LTP current of 2mA so Rc = 700R, 1mA per side. (collector resistor only used on one side of the LTP) A Rc of 1.4K will force a unbalance of 1.5mA/0.5mA and this will force the Vbe's of the LTP pair to be different. Nevertheless the amplifier will still function quite happily. (With assymetric slewing and more DC offset and distortion). |
#85 | |
Account Disabled
slightly different numbers (multisim): voltage drop upper collector resistor, voltage drop off lower collector resistor, and current through the VAS. with no VAS emitter resistors: 728mv, 781mv, 30.8ma; with 1ohm VAS emitter resistors: 752mv, 806mv, 27.8ma; with 10ohm VAS emitter resistors: 853mv, 907mv, 14.7ma; with 100ohm VAS emitter resistors: 938mv, 994mv, 2.8ma; do you guys spot a problem? I have no idea how the simulator calculated those numbers, I will try two other simulators later. |
#86 | |
allow Vbe differences to develop. With the circuit shown the the left and right Vbe's must be equal, not the case in real life. The circuit has no voltage input. If Vbe's are equal then Ic must be equal as shown, but this is putting the cart before the horse. |
#87 |
Account Disabled
protel dxp didn't do much better: it wouldn't simulate when the VAS emitter resistor is 0ohm, complaining about singular matrix.
again, the same formate: upper collector resistor voltage drop, lower collector resistor voltage drop, and VAS collector current. with 0.0001ohm VAS emitter resistor: 634mv, 1089mv (Wow!), and 12.55ma. with 1ohm VAS emitter resistor: 643mv, 1098mv, 11.82ma. with 10ohm VAS emitter resistor: 694mv, 1142mv, 7.73ma. with 100ohm VAS emitter resistor: 760mv, 1195mv, 1.85ma. BTW, all of them started to oscillate after about 15us, about 1 cycle per 0.1us (10mhz?). |
#88 | |
Account Disabled
not sure which base resistance you were talking about and which "left" and "right" you were talking about. It actually had a 10k resistor from the non-inverting end to the ground. and it does have a signal source (1vp, 1000hz). the Vbe difference you saw (on the two resistors) are due to difference between npn and pnp devices. |
#89 |
I've realised one thing :
each LTP pair in the double ended circuit does not need to be balanced, the double ended nature of the circuit will cancel distortion the same way a single ended LTP pair that is balanced will. So my original comment about "input balance" is wrong, the input is balanced, whether each LTP pair is irrelevant. But the balance of each pair needs to be known to know the VAS current, this balance and the VAS current is still indeterminate, in that its not easily calculated. I'm sure it is deterministic, but my maths aren't up to the job. Enter a simulator, with all relevant circuit values. What I am sure about is a Rc value gives a VAS current and the current balance in each LTP pair, and that one cannot easily calculate either without assumming one. Unless I've missed something.......... |
#90 | |
the theorectical case), each LTP pair bases summing horizontally must have the same Vbe, (which is why Ic's are equal), and this circuit has no voltage input, as it has no base resistances. The value of Rc only determines the output current, theorectically. |
| How to minimize 150W amp to 25W | ro9397 | Pass Labs | 1 | 2nd October 2007 03:41 AM |
| F/S 150w MH ballast | phaze5 | Swap Meet | 5 | 26th April 2003 05:56 PM |
| Page generated in 0.16001 seconds (72.49% PHP - 27.51% MySQL) with 11 queries |
