Good Dual Opamp >+/-15V suggestion
Old 15th February 2004, 11:58 AM   #1
Alvin is offline Alvin  Hong Kong
Default Good Dual Opamp >+/-15V suggestion
I would like to modified my Denon A1SE 7.1 channel AV amp.
I find 4 AD1853 DAC, and 8 OPA2134 and 8 LM833 in the digital board. The opamp are measured in +/-15V (total 30V) operation.
I want to use AD8620 but it +/-13V seems cannot meet the voltage requirement.
I want like to ask which opamp is the another best alternatives?
AD8512
AD826
OPA2132
OPA2111
Please suggest. Thanks!
Old 15th February 2004, 01:43 PM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I have run my QRV-04 headphone amp for nearly a year now at +- 15 volts with AD8610. Nothing to recommend for a commercial product but for home use and with stabilized voltage I think it's OK.
AD8610/20 is really, really good!
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 15th February 2004, 03:45 PM   #3
maylar is offline maylar  United States
For dual units I'm personally fond of the Linear Technologies LT1013.
dave
Old 15th February 2004, 05:02 PM   #4
5th element is offline 5th element  United Kingdom
5th element's Avatar
Hmmm I dont know where abouts the 2134's are used in the Denon, but they are one of the best out there anyway. Obviously you can do better, like peranders says the AD8610/20's are v good. I use these for the tweeter leg in my active xover and are very good. OPA627's are also good they do the mid leg in my active. Runs over to mic preamp...... looks at chip in it, aha yes the AD797's are also good. M levinson uses them in their amps. 797's are also meant to be good in I/V stages after the DAC chip in DAC's, if they are stable and do not oscillate that is!
Good luck improving the sound, however 2134's are not bad at all, so any gains you will get mite only be quite small, unless there is something i am missing! I use 2134's in my DAC's IV and the bass leg on the old active.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 16th February 2004, 12:12 AM   #5
Default AD8620 really suitable for +/-15V operation?
OPA2134 seems to be a quite good dual opamp from others' comments. I would like to replace the cheap LM833 first.
I would like to know if the excellent AD8620 can really work in exact +/-15V operation? Anyone further has such experience?
What will be the good partner of opamp with OPA2134?
Thanks!
Old 16th February 2004, 09:25 PM   #6
Gunders is offline Gunders  Norway
May OPA604 be an alternative?
OPA604 can take supply voltages up to +/-24V.
The SR is 25V/uS, GBW=20MHz, noise = 10nV/sqrt(Hz), CMRR(Min)=80dB, offset(maks)=5mV and they are available as doubles.
For more informations:
http://focus.ti.com/docs/prod/folders/print/opa604.html
And not to forget... they are rater cheap too.
Old 17th February 2004, 12:08 AM   #7
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
Default A little advice (was Re: AD8620 really suitable for +/-15V operation?)
The folks who design, build and test the device (Analog Devices) say don't use more than +/- 13V (see the data sheet)!!!
That's pretty clear to me; just don't do it unless you will live with the consequences.
mlloyd1
Originally posted by Alvin
.... I would like to know if the excellent AD8620 can really work in exact +/-15V operation? ....
Old 17th February 2004, 07:46 AM   #8
peranders's Avatar
Default Re: AD8620 really suitable for +/-15V operation?
Thanks!
See my post above!
The maximum rating is 27,6 volts in total so everything above is a risk but if you are prepared to take it, go for it. If you are unsure, just put voltage to the IC when they are not in the circuit and test them for a week or so. If they last a week the will probably last longer also. Don't forget to connect them so they work in linear mode, voltage follower maybe.
Old 17th February 2004, 09:40 AM   #9
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I would be very carefull, and not take the risk. Even if they still "work" after a week, the performance, noise, gain etc may be heavily degraded, and you amp will perform much below potential. Just set the supply to +/- 13VDC, what's the problem with that?
Jan Didden
Old 17th February 2004, 09:45 AM   #10
peranders's Avatar
If I would really plan to use AD8610/20 I would never use more than +- 13 volts on purpose but in my case I was just too lazy to change resistors at the regulators.
Good Dual Opamp >+/-15V suggestionHide this!Advertise here!
Need a opamp suggestion to replace a NJM4558D gaetan8888 Solid State 59 5th April 2012 07:26 AM
Opamp suggestion for DC-servo in an Alexander amp peranders Solid State 12 19th June 2004 06:18 PM
Is the NE5532N Dual Opamp any good? PaulHilgeman Digital Source 64 24th December 2002 11:52 AM
one-shot dual opamp suggestion dorkus Parts 4 21st May 2002 04:59 AM
