Old 15th February 2004, 12:27 AM   #1
Account Disabled
Default inductance multiplier
capacitance multipliers are pretty common. How about inductance multiplier, either in a ps or as a load (more difficult)?
any thoughts?
Old 15th February 2004, 03:46 AM   #2
jackinnj's Avatar
you mean a gyrator?
Old 16th February 2004, 01:52 AM   #3
Hello -
I think what he means is some type of circuit that could "multiply" the value of a given inductor. This would be especially useful when trying to build an inductor-input power supply filter. Normally the required inductor is so large and heavy that it roughly doubles the overall cost of the power supply. If there were a clever way to use a "small" inductor and "multiply" its action, then you could make an inexpensive amplifier that had inductor-input power supply filtering.
Unfortunately, this is just a wild goose chase.
A "capacitance multiplier" only mimics one aspect of a capacitor -- it's tendency to oppose a change in voltage. However, a "capacitance multiplier" does *not* multiply the energy stored in a capacitor. (If it did, then we could get rid of all the big capacitor banks typically found in high-quality amplifiers.)
So the analog to a "capacitance multiplier" would be a circuit that tends to oppose changes in current -- i.e., a constant-current source. However, this circuit doesn't increase the energy storage. You would still need a big inductor that would store enough energy to supply a constant charging current to the filter caps.
I think the confusion begins with the misleading term "capacitance multiplier".
Hope this helps,
Charles Hansen
Old 16th February 2004, 02:36 AM   #4
Account Disabled
this is what I had in my mind, conceptually.
you can certainly work out the math to see how this whole thing looks like from V1's point of view and compare that to an inductor.
Old 16th February 2004, 04:26 AM   #5
Hello -
You can ignore my previous post. It looks like jackinnj was right and that millwood wanted a gyrator. Here's one link:
http://www.epanorama.net/documents/telecom/gyrator.html
Best regards,
Charles Hansen
Old 16th February 2004, 10:57 AM   #6
Account Disabled
Originally posted by Charles Hansen
Hello -
Best regards,
Charles Hansen
that's the same set-up as the one using op-amp. Has anyone actually used such a circuitry?
Old 16th February 2004, 11:04 AM   #7
JensRasmussen's Avatar
Send a message via ICQ to JensRasmussen Send a message via MSN to JensRasmussen
Default Gyrator
I use the gyrator for making EQ's in my active x over.
Documentation will be ready soon.
\Jens
Old 16th February 2004, 11:43 AM   #8
Default Ups I forgot this
The schmatics and math
The circuit forms an RCL circuit
C is C1
Old 16th February 2004, 12:31 PM   #9
jackinnj's Avatar
Default Re: Gyrator
a gyrator is used to make the RCL transform from active xo to passive
Old 16th February 2004, 12:56 PM   #10
Default Re: Re: Gyrator
passive to active or active to passive does it really make much difference. The circuit I posted acts like an RCL series connection, with the component sizes as noted.
Well I use it in a voltage devider and in the feedback of opamps as a frequency dependent resistor, This creates an EQ..... works great too
\Jens
VBE multiplier fglabach Solid State 23 12th June 2009 04:56 AM
Vbe Multiplier Help Please mefistofelez Solid State 2 6th December 2004 06:14 PM
cap multiplier or not? PederBass Solid State 13 23rd March 2004 06:26 PM
Multiplier car amp Kilowatt Solid State 19 7th September 2002 02:40 PM
Page generated in 0.12920 seconds (68.20% PHP - 31.80% MySQL) with 11 queries
