Old 14th February 2004, 02:13 PM   #1
Default What do you think about this schematic?
Hi all!
I once built this amp, and I'd like to hear some comments about the schematic... Is this a potentially good design? And (if there can be) what improvements can be made?
It's a 40W Rms (8 ohm) Class AB amp.
Thanks!
Old 14th February 2004, 08:33 PM   #2
Dragance007's Avatar
Send a message via ICQ to Dragance007
Smile Advice
Well...i belive it works fine...but it is a little bit old design...
I belive it can be upgraded in many ways...
You can try some other design that is allready much better than this.
Old 15th February 2004, 12:05 AM   #3
pjacobi is offline pjacobi  Germany
Send a message via AIM to pjacobi Send a message via MSN to pjacobi Send a message via Yahoo to pjacobi
Hi Dave!
The capacitor coupling between Q1 and Q2 can be avoided by replacing one of them with PNP type. Replacing Q1 would need fewer changes.
For other points refer to this fine article:
http://sound.westhost.com/project12.htm
Apart from the above mentioned, rather awkward capacitor coupling, your circuit corresponds to Fig.2 (Fig.1 showing the older quasi-complementary output stage). A suggestion is made, how to achieve DC coupling the speaker (Fig. 3).
Peter Jacobi
YMMV
Old 15th February 2004, 12:41 AM   #4
Pedja is offline Pedja  Serbia
Exclamation Dave Weckl?
You mean, you are that Dave Weckl?
Pedja
Old 15th February 2004, 10:32 PM   #5
This design is similar to what we used to design in the middle '60's. This was because pnp devices were much more expensive than caps and npn devices. It is best to direct couple where possible, so using a pnp device for the second stage removes the internal coupling cap, and makes the design better.
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 01:49 PM
DBX 500 schematic d3imlay Solid State 0 2nd August 2008 05:12 PM
F3 schematic kenev Pass Labs 2 24th January 2008 03:24 PM
Need Six-pac amp schematic Sarge Tubes / Valves 1 31st July 2004 08:30 PM
Page generated in 0.07727 seconds (74.85% PHP - 25.15% MySQL) with 11 queries
