#11 | |
Sorry, but I am missing the point what you actually want to tell us. Regards |
#12 | |
This is another possibility to let a LTP input work into a low Z node and consequently resulting in a single voltage gain stage. See these schematics: Symmetrical version: PDF: http://www.linearaudio.de/scratch/fo...ascode-sym.pdf LTSpice: http://www.linearaudio.de/scratch/fo...ascode-sym.asc Asymmetrical version: PDF: http://www.linearaudio.de/scratch/fo...scode-asym.pdf LTSpice: http://www.linearaudio.de/scratch/fo...scode-asym.asc Some observations: - It's not straightforward to mix this with a diamond input stage, as you must add 180° somewhere for the right polarity. - Especially the symmetric version behaves in simulation very similiar to a diamond+current mirror topology. It would be most interesting to compare measured and perceived performance - Further cascoding with JFETs will give those low THD numbers in simulation, which are often laughed about (but not near -300dB as Bernhard reqularely achieves...) - Curiously, in the asym version K2 and K3 are of same (low) height wheras in the sym version K3 is 10dB lower. Go figure! Regards, Peter Jacobi
-- YMMV |
| DVI switch, worry about frequency? | ak_47_boy | Everything Else | 10 | 24th November 2007 02:51 AM |
| Impedance peak (worry or not?) | arc2v | Multi-Way | 1 | 26th October 2007 10:03 PM |
| Buying worry | Dr.EM | Everything Else | 2 | 8th October 2007 01:40 PM |
| BOZ voltages, worry or not? | bays_9a5tt | Pass Labs | 2 | 7th September 2005 10:03 AM |
